edit..damage pix up!! pix from first time wheelin!
Discussion in 'The Garage' started by supersize75, Sep 29, 2003.
  1. supersize75
    supersize75 1/2 ton status
    Sep 27, 2002
    2,638
    gilbert az......by Phoenix
    here is Harly "hossbaby", Eli "Weisel" and Andrew 77k10?
    42 inches and the front shock was stoping me! I added ford shock towers an hour later so next time should be better!
    Here is eli stuck! Guess who pulled him out /forums/images/graemlins/thinking.gif
    He tore a side wall and couln't start is truck for a day, we actually barried my rear tires for an anker, then used the high lift as a winch..did I mention my bumper only had 3 bolts on it and no nuts /forums/images/graemlins/crazy.gif
    Here is Harly and I in the tire pit /forums/images/graemlins/smile.gif
    we also hooked up a boat that we found and drug it around at speed, after wards I nailed it and smashed by front end a little /forums/images/graemlins/tongue.gif Also munched a rocker driving over it so now I will do the boat siding /forums/images/graemlins/thumb.gif
    more pix of bumper and tire carrier we built later /forums/images/graemlins/thumb.gif
  2. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    Re: pix from first time wheelin!
    Come on Sean its Harley with an E. Looks like you had a good time Saturday night, or did you go back out after I left at 3am on Friday. Where did Eli get stuck at? That same mud hole he went threw earlier? Later Shawn.
    Harley
  3. supersize75
    Sep 27, 2002
    2,638
    I beleave it was a different mud hole, funny though there I was blind as a bat with flash burn, and we are pulin out this truck,,,hmm I as searching for a metaphore /forums/images/graemlins/thinking.gif the word fun doesn't come to mind /forums/images/graemlins/rotfl.gif
  4. Hossbaby50
    Sep 1, 2001
    8,972
    Peoria, AZ
    I guess I ginxed you with that. I shouldn't have explained flash burn to you, or maybe I should have told you about it earlier. /forums/images/graemlins/blush.gif Hurts don't it. Where are the rest of the pics at for the buildup and wheeling? where is the pic of you on that concrete crack?
  5. supersize75
    Sep 27, 2002
    2,638
    Amazingly there are no build pix /forums/images/graemlins/tongue.gif
    I will post the crack tonight, also more tire pix, to bad there is no pix of the boat that I rear ended /forums/images/graemlins/ignore.gif
  6. weisel
    weisel 1/2 ton status
    Feb 22, 2001
    491
    Laveen, AZ
    I still can't belive you crossed a 6 foot tall, 20 foot thick, WALL of tires. I guess you had to make up for not making it through the lumps.
    Mabey crossover would have helped, but then, I don't have crossover either.
    I might have made it out of the mud, but my dist got filled with mud. I can't belive mud got in there.
    Ya, its a different mud hole.
  7. 77ChevyK10
    77ChevyK10 1/2 ton status
    Feb 2, 2003
    317
    Laveen, AZ
    the hi-lift pulled Eli out.
    Andrew
  8. supersize75
    Sep 27, 2002
    2,638
    no need to be technical now andrew...but who's truck was the ancher /forums/images/graemlins/thinking.gif
