Edited*Name that seal? New pic w/ new problem!
Discussion in 'The Garage' started by stallion85, Feb 26, 2004.
  1. stallion85
    stallion85 1/2 ton status
    Jul 11, 2003
    3,659
    Cedar City, UT
    This is why I wanted to rebuild my steering box. I figured just the one seal needed to be replaced instead. What do you guys think. Change the seal or rebuild the whole gear box?
    This is where I need to replace the seal. Is it as easy as taking out that clip and pulling the old seal out? Do you guys know what it is called. It would make things easier when I go to the part store if I had an idea /forums/images/graemlins/deal.gif Thanks for any help in advance /forums/images/graemlins/whistling.gif
  2. 55Willy
    55Willy 3/4 ton status
    Jun 2, 2001
    9,946
    Keizer, Or
    Re: Name that seal? PIC included!
    most part stores will only offer a full box kit. like $10-$15 for all the seals.
  3. stallion85
    Jul 11, 2003
    3,659
    Cedar City, UT
    Thats cool I did not know it would be that cheap. I will pick one up this weekend. Hopefully I can figure out how to get the thing apart /forums/images/graemlins/1zhelp.gif /forums/images/graemlins/eek.gif /forums/images/graemlins/eek.gif /forums/images/graemlins/eek.gif
  4. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    Mine just started leaking bad there, after 21 years /forums/images/graemlins/thumb.gif If its really that easy I know what I'm gonna be doin' soon, and new rag joint too /forums/images/graemlins/thumb.gif
  5. rcpilot
    rcpilot 1/2 ton status
    Feb 22, 2002
    507
    Central Cali
    AutoZone, Kragen and PepBoys I know for sure carry the "Input Shaft Seal" kit.. it's $6 and some change. You don't need to buy a complete rebuild kit. I also need to do mine... I was told it's a simple procedure.. you will only need to replace the seal and dust shield. There are other parts in the kit... just toss them in your spare parts box..
  6. 4xcrazy
    4xcrazy 3/4 ton status
    Oct 31, 2003
    9,471
    5
    Olympia/Lacey, Washington
    Mine was leaking, i was too lazy to replace it at the time, so i just put in some brake fluid, not alot, maybe 3-4 capfulls. Leak is gone for now. for now that is...... /forums/images/graemlins/thinking.gif
  7. supersize75k5
    supersize75k5 OrganDonorRacing.com
    Feb 3, 2004
    8,832
    4
    gilbert az
    After a run in with a tree and rock..on the side of a hill..."stupid quads with no lights and drunk wierdo's"
    I blew my rag joint apart, the who thing not just the replacable part, I ended up getto rigging it to get home and the stress of not haveing a rag joint blew out that seal, I have it from a-zone 6 bucks, as for the rag joint it killed the non replacable part, so rather that patch a problem I am just going to do the double u-joint steering shaft.
    Oly problem is I have the wrong shaft and colume /forums/images/graemlins/doah.gif
    Alwell the truck is motorless anyways /forums/images/graemlins/waytogo.gif
    easy fix to /forums/images/graemlins/waytogo.gif
  8. stallion85
    Jul 11, 2003
    3,659
    Cedar City, UT
    Does anyone know how to get this stinking thing off? I got that c clip out, but can't figure out how to get the outer ring off? /forums/images/graemlins/angryfire.gif
  9. 87GMC
    87GMC 1/2 ton status
    Nov 5, 2001
    653
    Olathe, KS 66061
    You need a wrench that fits into the two small holes to unscrew it. I think it's called a spanner wwrench.
  10. 4xcrazy
    Oct 31, 2003
    9,471
    5
    What is that snap ring in the middle holding in? something under the outter ring?
  11. stallion85
    Jul 11, 2003
    3,659
    Cedar City, UT
    That inner ring is holding in a gasket or seal of some sorts.
