Edlebrock or Holley
Discussion in 'The Garage' started by Wishbone, May 13, 2006.
Edelbrock or Holley
Poll closed May 20, 2006.
  1. Edelbrock
    29 vote(s)
    63.0%
  2. Holley
    17 vote(s)
    37.0%
  1. Wishbone
    Wishbone 1/2 ton status
    Mar 6, 2006
    239
    Oklahoma
    With all things being equal which one would you rather have on your carberated Blazer?
  2. blank
    blank Registered Member
    Apr 15, 2005
    64
    Texas
    I have had both for many years and I prefer the Edelbrock.
  3. garlicbreath
    garlicbreath 1/2 ton status
    May 17, 2003
    1,136
    Denver
    Every holley I have ever had needed constant babysitting to run good, and leaked. Made more power than edlebrock though.
  4. nstarry
    nstarry 1/2 ton status
    Feb 13, 2004
    349
    st.cloud minnesota
    more power from holley and better reliabilty in the edelbrock
  5. mostwanted
    mostwanted 1/2 ton status
    Feb 5, 2006
    765
    Kansas City, MO
    Okay, I read an article in Petersons 4wheel offroad a couple months ago on the Holley Truck Avenger. The article said that it would handle 40 degree inclines without stalling and 30 degree sidehilling. 40* don't seem like that much. I realize that a person could always go FI. Anyone running these carbs? I have also heard that a good Q-jet is good for wheeling.
  6. chevydan3
    chevydan3 1/2 ton status
    Nov 27, 2004
    409
    Reno, Nevada
    Go Edelbrock. Less pieces to worry about, easy to tune and work on. Get the off-road needles and seats, search this sight to find the float adjustment, 3/8" I believe. Those 2 mods and a proper rod/jet combo will work great. I have the 1406 on my truck.
  7. JEBSR
    JEBSR 1/2 ton status
    Dec 23, 2004
    1,541
    Clarksville, TN
    for performance you cant beat a holley. However for reliability and long term drivability without ever touching it, you can't beat the edelbrock
    Therefor if racing use the holley
    If a DD or trail rig used the Edelbrock
  8. mouse
    mouse 1/2 ton status
    Nov 10, 2003
    1,448
    Great Falls Mt
    Before going TBI an Edelbrock 1406 with the offroad seats worked pretty good for me (still have it for sale...). It was easy to tune and doesn't have a power valve (like Holleys) that go bad if you backfire through the carb.
  9. mtn. burb
    mtn. burb 1/2 ton status
    May 13, 2004
    1,260
    Ojai Calif.
    An old Rochester Quadrajet correctly rebuilt worked better than the new Holley in Bobby's 67' w/ a new ZZ3.
  10. realsquash
    realsquash 1/2 ton status
    Jul 12, 2000
    778
    SE WI
    Amen to that!
    Andy
  11. Chevy305
    Chevy305 6 Lug 14bsf Status Premium Member GMOTM Winner
    Jan 23, 2006
    11,230
    488
    New Hampshire
    Its Holley for me! You definately have to tune the thing more than once, but there is so much tuneability in a Holley. Plus Way more power than a Q-Jet.
  12. mrk5
    Apr 20, 2004
    12,333
    1,043
    Northern Colorado
    Truck Avenger specifically.
  13. onetonbb74
    onetonbb74 1/2 ton status
    Dec 1, 2005
    2,083
    Campbell, CA
    ive had an edelbrock, holley, and a q jet and with gas so damn expensive, i stick with the q jet. The edelbrock worked but would stumble a little under hard throttle and stalled a few times. The Holley never stumbled, but it sucked the life out of my wallet because it was a double pumper and it stalled all the time but on the street it was the best, the q-jet lacks the power but never stalls and works great and i get killer mileage for a full time 4x4.
  14. K5TRLBLZR
    K5TRLBLZR Registered Member
    Mar 31, 2003
    52
    Elk Grove Ca.
    I'll take a well built quadrajet anyday. I've had gas pouring out the filler cap & kept putting along. Once you get the float right it makes for good times.
    I let people talk me into tbi for my new build, I hope it works out.
    Good Luck
  15. RootBreaker
    Nov 29, 2001
    5,117
    173
    Williamstown, NJ USA
    I read an article where they put one on a jeep... stood the jeep on the back spare tire straight up in the air.. it still ran..... then they laid it on its side and still ran.. supposedly all flops were by accident.. :haha:
    that article is the one that changed my mind from a qjet to avenger...
    x2 on that one...
    out of the box the truck avenger has issues... need the accelerator pump cams kit... put the biggest one on this weekend..... the black one..
    now my off the line stumble is almost gone.... a bit more tuneing and will be good...:bow:
  16. blazinzuk
    blazinzuk Buzzbox voodoo Premium Member GMOTM Winner
    Dec 20, 2002
    17,412
    3,799
    Afton / Star Valley Wyoming
    I didn't vote because of two things one the low throttle response of a quad is much better than either. Mileage. I have two freinds with truck avengers, after much tuning they both run great. Lost 2 mpg to the quads they were both running before. The holly seems to pull harder on the top. I have tried all the little tricks with the edelbrocks on 5 or 6 different rigs. They all ran good none of them ran great. Its hard to find a good q jet guy but I personally think the q jet is the better carb of all of them, they are just way harder to work on
  17. Chevy305
    Jan 23, 2006
    11,230
    488
    New Hampshire
    You can adjust a Holley so its not all top end power. It is all in the float bowls. When you change the float level you actually change the fuel curve so you need to find that sweet spot between all out see of your pants top end power and low end testicle desending power.
  18. GM Man
    GM Man 1/2 ton status
    Jan 12, 2003
    549
    Denver CO
    Im running a Holly TA in my Jimmy and after the initial install/adjustments it has ran fine with no other adjustments needed..
  19. Kamots
    Kamots Registered Member
    Oct 9, 2002
    47
    Oklahoma
    Not to hijack the thread, but wishbone ur blazer looks exactly like mine. And im in Oklahoma as well....hehe.
    Kamots
  20. Wishbone
    Mar 6, 2006
    239
    Oklahoma
    Cool, I'm in the Okc area so if you see me around stop and and say hi.
