EFI fuel pump to carb
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by rcamacho, Jul 12, 2004.
  1. rcamacho
    rcamacho 1/2 ton status
    Jul 1, 2004
    1,324
    WA
    My '87 was set up with a Carter Comp. AFB plumbed to the in-tank EFI pump. The carb has an inline regulator which appears to be plumbed into a return line.
    The regulator spikes to 7 psi after ignition on and then jumps back to ~4 repeatedly.
    Q: It seems like I need to adjust the regulator down more or check the return for obstructions. Any suggestions?
  2. Thunder
    Thunder 3/4 ton status
    Jul 20, 2000
    8,946
    Northeast Nevada
    If yur not having problems with it. I think you should leave that set up alone. Or replace it with a inline pump meant to be used for a carb.
