EFI pump placement
Discussion in 'The Garage' started by TexasDan, Oct 2, 2006.
  1. TexasDan
    TexasDan Registered Member
    Dec 13, 2004
    28
    Texas
    I need some advice. I'm installing 2 fuel tanks in my project. I don't want to put fuel pumps in the tanks. If I put a low pressure electric pump on each tank, connect these to the fuel control valve then install a high (45 psi) pressure electric pump just after the valve and connect to the TPI sytem that I have, will this work or am I asking for problems?
  2. 1979jimmy350
    1979jimmy350 1/2 ton status
    Mar 24, 2004
    3,069
    Ann Arbor Mi
    you will need pretty high volume low pressure tanks and some type of surge tank to provide a resivor for extra gas after the valve and before the high pressure pump. Your best bet would be to get TBI dual tanks and just replace the fuel pump with a high pressure one
  3. btolenti
    btolenti 1/2 ton status
    Sep 28, 2003
    644
    Gilroy, CA
    not sure, but it sounds complicated!
