EFI tank
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by BigJohnson, Mar 17, 2004.
  1. BigJohnson
    BigJohnson 1/2 ton status
    Jan 22, 2001
    207
    AL
    I am finally getting around to installing my TBI and I am swapping to a 31gal EFI tank and pump setup.
    Advance auto and others have a replacement tank for $99. Chevy duty has a tank for $149. Does anyone have any experience with either of these tanks? I am concerned that the cheap replacement tanks might be just that...cheap. I am open to suggestions.
  2. marine_enlisted
    marine_enlisted 1/2 ton status
    Sep 29, 2002
    658
    Stafford, VA
    Make sure that the cheap tank has the baffles in the bottom. It may be cheap because it has none. If you run TBI without them your truck will cut out when you get low on fuel and turn sharp or ascend/descend a hill. You probably already knew this, but just in case. /forums/images/graemlins/thumb.gif
  3. BigJohnson
    Jan 22, 2001
    207
    AL
    Good point I didn't think about that. Yep I am going this route to get the baffles and eliminate the need for a surge tank. I figured if the parts were available and a bolt in deal why not. Plus I think in-tanks pumps are quiter, and last longer. /forums/images/graemlins/cool.gif
  4. bablazer73
    bablazer73 1/2 ton status
    Apr 4, 2000
    3,363
    upstate ny
    I 2nd that with the baffle's. Somebody replaced the tank in My 87 and it doesn't have the baffles. I have no idea where the tank came from.
  5. Mastiff
    Mastiff 1/2 ton status Premium Member
    Jul 21, 2002
    2,755
    48
    Tucson, AZ
    How bad is it without baffles? I've ordered an EFI upgrade kit, but I really hadn't planned on replacing my gas tank. I thought most people just installed an electric pump in the fuel line on the frame rail. I already have a return line, so I thought I was home free.
    Why is it different with a carb vs. EFI?
  6. 4xcrazy
    4xcrazy 3/4 ton status
    Oct 31, 2003
    9,471
    5
    Olympia/Lacey, Washington
    Mine cuts out even with the factory tank, /forums/images/graemlins/dunno.gif and it does have the baffles, /forums/images/graemlins/thinking.gif but then again, maybe i'm running it tooooo low? /forums/images/graemlins/doah.gif /forums/images/graemlins/doah.gif /forums/images/graemlins/doah.gif /forums/images/graemlins/doah.gif /forums/images/graemlins/doah.gif
    I'd go with the Suburban tank, just a little bit bigger, and is a 40 gallon tank, go for that big bill at fill ups like us with the Burbs do. /forums/images/graemlins/thumb.gif /forums/images/graemlins/whistling.gif
  7. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    what exactly is diff from EFI to carb tanks anyways ? why cant ou put EFI assembly into a carb tank or vice versa ?
    also form everything i have seen and or read you want to try and always keep at 1/4 or more with an EFI vehicle, the pump is lubricated by the fuel only and if you run it low well then you run low on pump lubrication too and that is bad for the pump of course
    good luck
  8. 4xcrazy
    Oct 31, 2003
    9,471
    5
    Not so much lubrication, but it is a submerged pump, keeping fuel in the tank ensures that the pump is staying "cool" in the fuel. A constantly hot pump will burn out real quick. Same for Diesel engines/fuel tanks.
  9. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    that is with the stock pump and it is cooled by the fuel, but could be lubricated also /forums/images/graemlins/dunno.gif
    the aftermarket pumps (inline) are not cooled by the fuel running throught them, but by the air around them
    the diff between the tank AFAIK is the baffel, to keep fuel around the sender
  10. BigJohnson
    Jan 22, 2001
    207
    AL
    Will the Burb 40gal tank fit? I think the deminsions are the same except for the height and that difference is only a few inches. If it will fit I might as well get the 40gal. That should put my mileage on one fill up to...I don't know say 200 miles /forums/images/graemlins/grin.gif
  11. BigJohnson
    Jan 22, 2001
    207
    AL
    I wouldn't worry about it too much. I know several people with TBI swaps and non-baffled tanks and they have no major problems. BUT if you run it low and make a hard turn or you are climbing a hill it will starve the pump and it sometimes will not re-prime until you have a fair amount of gas in the tank.
    Here is a site that has a cheap surge tank filter combo. Look under fuel system for filter/accumulator. I don't think it would have a large capacity but it would probably help. I also think you could make one yourself for cheap. You could probably rob a diesel firewall mounted filter setup and modify it. If you look at their diagram they are running two pumps low and high pressure. I think the best way to do this on a Blazer is to use your mechanical pump as the low pressure side and pump into the filter/accumulator and then put a external high pressure pump on the other side. Then you have an effective surge tank/filter.
    OR....you could just try to always have more than 1/4 tank. That is the most simple approach but I am anal and want the baffles and in-tank combo.
  12. 4xcrazy
    Oct 31, 2003
    9,471
    5
    That is one thing i have learned from experience when i go wheelin, i always fill up the tank before i go, i have been in situations where i started runnin around half a tank or so and when i started climbing up a hill it would starve out and die, well once i had to climb the hill to get out of the area, so i had to do it in reverse /forums/images/graemlins/doah.gif
    Thats fun /forums/images/graemlins/peace.gif
  13. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    i like that idea, too bad my cam doesnt have a fuel pump lobe. i really dont like the idea of having to mount a fuel pump under the truck.
  14. u2slow
    u2slow 1/2 ton status
    May 9, 2001
    2,217
    BC Canada
    I bought a cheap jobber tank (31-gallon) for $120CDN and it had baffles. Its application specific. Make sure you ask for one for an 87-91 K5 and its baffled.
    Maybe a 40-gallon fits under a longbox. The tank is 36" long... 6" longer than the K5 tank. There was only enough room for a 31-gallon under my 1-ton shortbox. Even so, I had to remove the passenger side shock /forums/images/graemlins/wink.gif
  15. K30CJ
    K30CJ 1/2 ton status
    May 16, 2003
    429
    IN
    Same here. Mine has stalled on steep hills a couple times (usually some bouncing is involved also), but the tank was a low on fuel. As long as I fill up, I can wheel at 2 or 3 days without a problem. My jeep has a stock tank, inline electric pump and TBI motor, and no break tank.
