Egged out shock mount on 83 Jimmy
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by tackettb, Jul 19, 2002.
  1. tackettb
    tackettb Registered Member
    Jul 18, 2002
    49
    Tacoma, Wa
    My Right Rear shock came loose and must have been wiggling there for a while before the nut fell off because the mounting hole in the frame is too big and egg shaped. Anyone have any good advice on how to repair that? TIA! /forums/images/icons/confused.gif
  2. BLUESMAN
    BLUESMAN 1/2 ton status
    Oct 3, 2001
    951
    Phoenix(but it\'s a dry heat...like an oven!)AZ.
    You can what mt brother did,he had the same problem.He simply drilled a new hole about 2" down into the frame.Then installed a new shock stud which came with his shocks.I'm planning the same thing for a different reason.My shocks are too short,I only have 3" of down travel.
  3. dyeager535
    26,977
    I had this happen before, I welded the shock stud to the bracket. Problem solved.
