EGR Problems
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Adub, Dec 14, 2002.
  1. Adub
    Adub 1/2 ton status
    Aug 16, 2002
    106
    OK
    Truck throws SES code 32 during highway driving. Idles fine. Sometimes it runs strong, sometimes weak, but I can't seem to find a pattern. Checked EGR by pushing diaphragm at idle, EGR passed. Replaced solenoid. Clear ECM, truck still throwing the code. Could my valve still be bad?
    AW
  2. azblazor
    May 5, 2001
    1,953
    Arizona, Phoenix area
    You might try taking the EGR valve off and cleaning it, sometimes they get fouled up.
  3. K5 NUTT
    K5 NUTT 1/2 ton status
    1,611
    Grand Junction Colorado
    When you pushed on the diaphram did it kill the engine? It should.
    You also need to see if the valve will hold a vacum with a mighty vac...my 79 threw a cel last night....as i slowed down it went out. After i stopped and shut it off it would not restart...after eating dinner and a quick peek under the hood it started....but when i got home it wouldn't start agin. This afternoon i hooked up my scanner and had a hard fault of 32....egr circuit....my valve held a vacum...so i replaced the egr solenoid with a spare...unhooked the batt and cleared the code.....then road tested the truck with the scanner it road test mode....no problems since.
    Azblazer
  4. 87sm465np208
    87sm465np208 1/2 ton status
    Aug 28, 2002
    1,114
    illinois
    to clean them egr valves you gotta hit the thing with a hammer right? /forums/images/graemlins/thumb.gif
    /forums/images/graemlins/usaflag.gif /forums/images/graemlins/truck.gif
