EGR solenoid
Discussion in 'The Garage' started by painterbccc, Nov 15, 2005.
  1. painterbccc
    painterbccc Registered Member
    Nov 12, 2005
    47
    Tennessee
    Can someone tell me where this thing is at? 1988 2500 4x4 auto 6.2 n/a motor. I heard that it messes with glow-plugs shift pattern of trans, makes a humming in radio. I got all those symptoms. I've had people show me the EGR valve. It has to have a electrial wire to it. Oh yea it should cost around $100.00 everything else does anymore.
  2. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    On the gas engines you can find it by following the vacuum line back from the EGR valve to the solenoid. A new solenoid for the gas rigs is $14. I hope it's that easy (and cheap!) for your oil burner... :rolleyes:
  3. diesel4me
    Jul 24, 2003
    17,561
    942
    Massachussetts
    its..
    Its right on the rear of the intake,next to the vacuum pump (if your motor has one,and I assume it does if it has an automatic tranny with a modulator,like a TH400 or Th350,and an EGR valve.)..its on the drivers side ,near the valve cover..you'll see the vacuum hoses and wires..mine is disconnected.. :whistle:
