egr system question
Discussion in 'The Garage' started by dheavychevy38, Sep 27, 2005.
  1. dheavychevy38
    dheavychevy38 1/2 ton status Premium Member
    Jan 6, 2003
    1,003
    Algonquin,illinois
    Ok i have a 91 k5 with a 5.7 tbi. When you take off from a stop sign or light the truck backfires and bucks horrible. It through the check engine light and it says the egr system. I am going to do a tune up and replace the egr any other ideas thanks Denny.
  2. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    Before you spend $50 on an EGR valve, remove the one that's on there and check to see if it has some carbon on the end of the pintle. If it sticks open, even a little bit, the engine will not run well. It might be something that you can clean up with a can of carb cleaner.
  3. dheavychevy38
    Jan 6, 2003
    1,003
    Algonquin,illinois
    yea thats what i was thinkin i am going to yank it off after work today and check the carbon out see if the port is built up along with the egr. Thanks for the reminder.
  4. 84zz4ss
    84zz4ss 1/2 ton status Premium Member
    Dec 28, 2004
    1,342
    Pensacola FL
    Also check the egr solenoid and it's vacuum source at the base of the throttle body. The passage can get clogged up and restict vacuum to the solenoid.
  5. dheavychevy38
    Jan 6, 2003
    1,003
    Algonquin,illinois
    Ok so i didn't get a chance to mess with the egr yesterday but the code it through to day was a 32 which is a vaccum error. On the egr their is only one hose going from the egr to the solenoid. Then their is a tab underneath of that connection is their any pics of where this should go Thanks denny,
  6. dyeager535
    26,976
    If you are talking about the EGR solenoid, there are only two vauum lines running to it, (source and EGR) but there is another nipple that is usually covered by a small foam block, which is just a vent. If the foam comes off, it looks like a hose is not connected where it should be.
  7. dheavychevy38
    Jan 6, 2003
    1,003
    Algonquin,illinois
    when i looked earlier their was only one hose going to it
  8. GEORGIA GABE
    GEORGIA GABE 1/2 ton status
    May 25, 2005
    1,070
    Conyers, ga
    im not sure if it is what is happening to your truck or not but if you fix what sounds like a vacuum leak and it still runs poorly at takeoff but gets better as you get up to speed you should disconnect (temporarally) the egr vacuum and plug the line. go drive it and see how it does. If it drives alot better then what happened is the spring inside the egr valve was weak and it was opening up too quickly. Just a thought. good luck with it.
    gabe :D
  9. dheavychevy38
    Jan 6, 2003
    1,003
    Algonquin,illinois
    Thanks i will try that to night i made sure i had good flow through the vaccum line from the tbi to the solenoid. Is their a was to check the solenoid to see if it is working properly. If i tap on the egr it gets better for a while.
