egr vacuum leak
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by steve85fla, Jul 9, 2002.
  1. steve85fla
    steve85fla Registered Member
    Mar 27, 2001
    83
    palm beach county FL
    I have plugged everthing I could find around the q-jet and manifold, could the egr be leaking? '85 350 q-jet
    Thanks!
  2. Shaggy
    Shaggy 3/4 ton status
    Dec 15, 2000
    6,737
    Los Banos, CA
    <font color="green"> Could be, stick your finger in the side of the valve and push the diaphragm open when the engine is idling, it should make the engine stumble and nearly die. Also - a mechanics stethescope is a great tool to help find vacuum leaks. When you get the tip close to the leak it should be very obvious
    </font color>
