EGR valve $70.00!!!!
Discussion in 'The Garage' started by COCHEV, Mar 16, 2003.
  1. COCHEV
    COCHEV 1/2 ton status
    Jul 9, 2002
    4,055
    Washougal WA
    Schucks quoted me 72 bucks for new egr. is this right?!?!? mine is bad on my 90 burb causing hessitation off idle. anyone know a cheeper source?
  2. jc71355
    jc71355 1/2 ton status
    Jan 13, 2002
    830
    Port Neches, Texas
    That's about what I paid for mine.
  3. milspecjimmy
    milspecjimmy 1/2 ton status
    Aug 28, 2002
    901
    raymond, maine
    i have a used one off my good running(lost a main bearing) 89 TBI 350, that ill sell you for a decent price.
  4. MudFrog
    MudFrog 1/2 ton status
    Feb 23, 2000
    3,236
    Daleville, Va
    Auto Zone wants $37 for mine, 89 350 TBI.
  5. COCHEV
    Jul 9, 2002
    4,055
    Washougal WA
    /forums/images/graemlins/shocked.gif /forums/images/graemlins/shocked.gif /forums/images/graemlins/shocked.gif /forums/images/graemlins/shocked.gif /forums/images/graemlins/shocked.gif
    wonder why the big price difference? damn, emision crap anyway. gotta have it though or the SES keeps coming on /forums/images/graemlins/tongue.gif
  6. jimmyjack
    jimmyjack 1/2 ton status
    May 11, 2000
    2,290
    Tucson Az
    Zactly what does the EGR do? I was chasing a vacuum leak and my mechanic buddy cut the hose and spliced it with a golf tee, thus blocking it off. Been that way for 2 yrs. I finally removed it last month.
  7. COCHEV
    Jul 9, 2002
    4,055
    Washougal WA
    egr intoduces exhaust gases into the intake at part thottle. when the little spring in the egr wears out it opens too soon causing too much air in the intake at part throttle and therefore causing hessitation. egr is supposed to reduce cylider heat and pressure and reduces nitrous oxide in the exhaust which means less emisions. it all translates to a big P.I.A.
  8. jimmyjack
    May 11, 2000
    2,290
    Tucson Az
    Hmmmmmm, well mines been out of service for 2 yrs and I have never had a problem at the emissions station as far as the EGR was concerned. I rebuilt the carb once cos I failed. Last time I went I asked about it and was told it isn't needed to pass emissions so I yanked it. I'd let you have it but the diaphragm is bad
  9. COCHEV
    Jul 9, 2002
    4,055
    Washougal WA
    if there is no vac signal to the egr it will stay closed. its when the egr is connected to a ported vac source and the egr spring is week it will open too soon and creat a sympom similare to vac leak or more air than fuel causeing a part throttle stimble. to test if your egr is bad just unhook the vac line and plug it and see if the bogging goes away.
  10. Zeus33rd
    Mar 14, 2002
    7,324
    9
    Grass Valley, CA
    $70 is nothin....I just bought a little Mitsubishy Mighty Max truck for a dd...It needed a new EGR to pass smog...$123! Believe it or not.. /forums/images/graemlins/ooo.gif /forums/images/graemlins/eek.gif
  11. bigblock454
    bigblock454 Clack Clack Clack Premium Member
    Jun 18, 2002
    546
    16
    Terre Haute IN
    Don't even replace it. Just make a blocking plate from some sheet metal and sandwitch it between the intake and the old EGR. If it fails smog then get a new one. This won't effect driveability.
  12. jeffro
    jeffro 1/2 ton status
    Jul 2, 2002
    406
    Scurry, TX
    If you do bypass the EGR valve you will increase the cylinder temperatures. This of course will cause detonation. But you won't notice if your knock sensor is working and retards your timing. But then you will have a slight reduction in performance and fuel economy.
  13. COCHEV
    Jul 9, 2002
    4,055
    Washougal WA
    i'll probably get around to it. i don't like my ses light coming on, plus with gas at 2.02/ gal i can use all the economy i can get!
  14. bigblock454
    Jun 18, 2002
    546
    16
    Terre Haute IN
    EGR is only for Emissions, maybe a very slight MPG, probably less than 0.5 MPG since you arn't burning the leftover gas in the exhaust. You won't notice performance because it isn't used (closed off) during full throttle. Why would it cause high cylinder temps?
  15. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    The main job of the EGR valve is lowering the combustion chamber temps at part throttle. This greatly lowers part throttle emissions (something not measured during an emissions test in most states) and best of all it reduces the tendency of the engine to ping at part throttle. This means you can run more spark advance. /forums/images/graemlins/thumb.gif The EGR valve is a good thing to have. /forums/images/graemlins/cool.gif
  16. MudFrog
    Feb 23, 2000
    3,236
    Daleville, Va
    Thats exactly why I'm replacing mine, it's pinging horribly.
  17. jeffro
    Jul 2, 2002
    406
    Scurry, TX
    Most people don't use full throttle most of the time. I'd guess that most driving is done at part throttle. The higher temps are caused by detonation. The reduction in performance and economy is due to the retarding of the timing (on TBI anyway) and the fact that you will use more accelerator to compensate for the retarded timing issue. The interesting thing is that most people will not notice, but they will get, say, 120,000 miles on their engine instead of 180,000 miles. My wifes '93 GMC has nearly 200,000 miles and it's still ticking along, with the EGR. But then, the sort of guy that would take off his EGR in the hopes of increasing his performance probably never got much more than 100,000 miles out of anything.
    Word.
    Jeffro
  18. bigblock454
    Jun 18, 2002
    546
    16
    Terre Haute IN
    Interesting I guess. But I still don't understand how introducing Very Hot exhaust gasses can reduce temperatures over indroducing ambient "outside" air. What is the actual science behind this?
  19. COCHEV
    Jul 9, 2002
    4,055
    Washougal WA
    someone smarter that me is going to have to drop some engine theory on this. it makes good sense to me but i can't seem to explain it very well. /forums/images/graemlins/tongue.gif
  20. HarryH3
    May 31, 2000
    10,384
    Georgetown, TX
    It isn't the temp of the incoming gases that cool the combustion chamber temps. It's the type of gases that are in the exhaust. They lower the temp of the actual combustion process by a few hundred degrees when introduced into the intake. /forums/images/graemlins/shocked.gif It's also a VERY small amount of gas that gets recirculated when the EGR valve opens. Search around on the web and I'm sure you can come up with the chemistry involved. Someplace like www.howstuffworks.com might be a good place to start. /forums/images/graemlins/cool.gif
