EGR valve ?
Discussion in 'The Garage' started by az ranger, Aug 18, 2005.
  1. az ranger
    az ranger 1/2 ton status
    May 9, 2004
    139
    Safford AZ
    a while back I replaced the EGr on my jimmy becuase any time I ran on the hwy for 20 min or so the check engine light would come on. If i ran it for long period of time 1 hr or more it would die when I stoped and idled. I dont remember exactly what trrouble code it was throwing but it had something to do with egr so I replaced it. now it is doing the same thing
    any Ideas
    the vacume line that hooks up to it is not hooked up right now, or before. When its pluged in it runs like sh!t... real rich
    thanks
  2. crazyhole812
    crazyhole812 1/2 ton status
    Jul 6, 2005
    228
    missouri
    did you try just leaving the hose unattatched and let it breath fresh air?
  3. camiswelding
    camiswelding 1/2 ton status
    May 25, 2003
    2,545
    Redding, CA
    Check and see if the truck is throwing a code 32... egr fault...
    1)test egr... replace if bad
    2)test egr control... replace if bad
    3)test ecm wiring ... fix if fault
    4)check ecm...
    now this is for tbi/computer controlled trucks
    if yours isnt then
    vacuum test the egr
    check 02 sensor
    this is just a start but Im flying blind without knowing the codes.... a obd1 tester is cheap... and that will help lead you to the correct cause
    cam
  4. shane74
    shane74 1/2 ton status
    Feb 12, 2002
    4,100
    Vancouver, WA
    Yes, it is possible to have it go bad quickly. I replaced my EGR with a NAPA unit and it went bad in less than a year. If it is your EGR, spring for the $100 OEM unit from the dealer. They have a better warranty too. Normally I would steer you as far away from the dealer as possible, but in this case, it's the only way to go IMO.
  5. dyeager535
    26,978
    How does the TBI EGR even know that it's working right or not enough to throw a code? I thought TBI EGR (truck anyways) is not computer controlled at all? Is there a temp switch somewhere in the EGR circuit?
    Gotta know whats in the circuit before you can delve into possible causes. I'm asking because I don't really know! If it can throw an EGR code, there must be something in the circuit monitoring EGR somehow.
    Edit: And a better option than the dealer is to get the part number from them, and order it from gmpartsdirect.com. My local dealer is not a friend, that's for sure. I won't even bother calling them anymore, because I know they can't get close to GMPD's prices.
