EGR Valve
Discussion in '1969-1972 K5 Blazer | Truck | Suburban' started by Johnny Buck, Apr 5, 2002.
  1. Johnny Buck
    Johnny Buck Newbie
    Apr 5, 2002
    Winston-Salem, NC
    On my rebuilt 72 454 in my Jimmy, the EGR valve has always been capped off ever since I have had it. I was wondering if this was a good idea, if it will do any harm or hurt/ help performance, etc. If it should be hooked up a vaccum fitting on my Q-jet, which one should it be on? Thanks a lot for any help.
  2. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    The EGR (Exhaust Gas Recurlation) is only for emitions. It will not hurt to not have it hooked up if it is blocked off well.
    The PCV (Positive Crankcase Ventilation) has to be hooked up...
  3. 4X4HIGH
    Dec 14, 2001
    22,063
    70
    Pleasanton, CA.
    I do not believe that a "72" even uses an EGR valve, I think you might have a later manifold on an early engine. I am pretty sure that EGR valves were not even used until around "75" or so.
  4. Burt4x4
    Burt4x4 3/4 ton status
    6,854
    California (Modesto area)
    Yup, No EGR on 72. Most likly someone swaped the manafold or the whole motor from a later modle....
  5. Steve_Chin
    Steve_Chin 1/2 ton status
    Mar 6, 2001
    1,126
    Foster City, CA, USA
    The first year for EGR in most GM divisions was 1973.
    EGR won't really hurt a lot of performance since it's vacuum-triggered. When you have the throttle mashed, your EGR is pretty much non-functional. Since its main purpose is to reduce the combustion temperature (in order to reduce NOx emissions), it can actually reduce the tendency for an engine to detonate under moderate throttle loads.
