Ehaust fumes and soft tops...
Discussion in 'The Garage' started by nvrenuf, Jun 10, 2002.
  1. nvrenuf
    Jan 7, 2002
    13,078
    246
    Mobile, Al.
    I'm going to be building a K5 and have some exhaust questions.
    Is there a preferred way to route exhaust for a soft top? I've heard that running turn downs or tail pipes straight out the back can cause fumes to come in the back window with a hard top, what about a soft top?
  2. muddin4fun
    muddin4fun 3/4 ton status
    Feb 19, 2001
    5,644
    N Texas
    No matter how you run the exhaust, it's going to suck some into the back window. It's the shape that causes it. If you have the sides rolled up on your soft top, you'll prolly be okay.
  3. tRustyK5
    Jul 23, 2000
    36,172
    1,381
    E-town baby!
    With the sides rolled up you get no fumes at all...other than that it'll be just like the hard top. Open rear window and it will suck in fumes...
    Rene
  4. nvrenuf
    Jan 7, 2002
    13,078
    246
    Mobile, Al.
    A friend suggested that running the tail pipes out at a 45 degree angle to each rear corner helped the problem (although it didn't go away). Since I'll have to have new pipe put on this truck is on route better than others? Or does it seem to be just as bad no matter which way?
    Thanks for the help!!
  5. tRustyK5
    Jul 23, 2000
    36,172
    1,381
    E-town baby!
    I had the tailpipes at 45 degrees and currently have them at 90 degrees right at the bumper. I didn't notice any difference...other then not breaking my exhaust hangers anymore.
    Rene
  6. 70~K5
    70~K5 1/2 ton status
    Apr 13, 2002
    2,032
    sillycon valley
    Well maybe if you were to run them up past the top of the truck like the milatary does on their fording kits that might help. /forums/images/icons/wink.gif
  7. chevyfumes
    chevyfumes Court jester
    Feb 24, 2000
    38,584
    266
    Watch for the muzzleflash!
    hey, don't hate the fumes.... /forums/images/icons/wink.gif
  8. bouncytruck
    bouncytruck 1/2 ton status
    Oct 11, 2001
    858
    Bothell, WA
    I have the pipes out the side behind the rear wheels, run with the soft top and I don't get the fumes too bad. It is definately better with the sides rolled up or the top down. /forums/images/icons/grin.gif
  9. 78Blazer
    78Blazer 1/2 ton status
    873
    Michigan
    I can not even hardly drive my truck any distance at all with out real bad fumes.. If I roll my windows down it is even worse. My truck has factory duals on it that is all in good shape.. I have to figure this out becuase I can not drive it like this.
  10. 74k5inVA
    74k5inVA 1/2 ton status
    Dec 13, 2001
    329
    Virginia Beach, VA
    check you manifold for exhaust leaks, could be that it isn't even in your pipes. mine was so bad that my eyes water and i got light headed in five minutes when in my truck. i have true duals, but one of my exhaust manifolds was missing a donut. i guess the previous owner took it out, don't know why. but i put that in and it is much better. Also replaced the distributor and reset the timing and now it burns no where near as rich making less gas in the exhaust.
