Eight-lug conversion backing plate
Discussion in 'The Garage' started by SUB-ZERO, Jul 18, 2005.
  1. SUB-ZERO
    SUB-ZERO 1/2 ton status
    Oct 8, 2002
    219
    Virginia Beach,Va.
    I have read all(at least most of) the threads about the eight-lug conversion for the front 10-bolts.I can see where anyone has mentioned where to find the backing plate other than the junk-yard.Around here the yards want you to buy the whole axle.Has anyone done this conversion..and where did you get your parts?Thanks.
  2. MattK
    MattK 1/2 ton status
    Jan 12, 2005
    1,713
    Dallas, TX
    i found my 8 lug parts from a seller on pirate4x4.com. shoot a pm to big mudder on there. i think he has several sets of 8 lug parts. all you need are the hub/rotor assembly and backing plates.
    dont forget to buy new bearings/races. while i had all this stuff pulled off i found it to be a perfect time to replace the balljoints and axle u-joints. it cost more money than i had planned when i started the project, but i drive a safer, more reliable truck.
  3. SUB-ZERO
    Oct 8, 2002
    219
    Virginia Beach,Va.
    Thanks I'll get up with him right away.
  4. stockk5
    Apr 13, 2004
    2,037
    73
    Cromwell, CT
    not to highjack but you dont need to replace the spindles like the article on here says? I wanna make my 10bolt an 8lug as well, but am having a hard time trying to figure out what exactly i need cuz i hear different stories from different people
  5. 6.2Blazer
    6.2Blazer 1/2 ton status
    Feb 24, 2000
    4,675
    26
    Ohio
    If you currently have a 6-lug 10-bolt, you can get the parts off of an 8-lug 10-bolt and will NOT need spindles.
  6. sandawgk5
    sandawgk5 3/4 ton status
    Oct 28, 2003
    6,881
    Kitsap County PACNORWEST
    The reason the article says to change the spindles is because they are doing the swap on a dana 44 which had two different spindle sizes between 6 and 8 lug. The 10-bolt is identical between 6 and 8 lug with the exception of the hubs, rotors, and backingplates. Maybe calipers but I am pretty sure your 1/2 ton calipers will work.
  7. sweetk30
    Nov 1, 2004
    25,546
    542
    horseheads , ny 14845
  8. shane74
    shane74 1/2 ton status
    Feb 12, 2002
    4,100
    Vancouver, WA
    I have been considering fabbing these parts. They aren't that hard to make, but is there a market for the effort? :dunno: :thinking:
    AFA as spindles go, if you have the large bearing D44 spindles, you can use them. If not, you'll need to go with a set of 10B spindles. They can be from an 8 lug or 6 lug 10B. They are the same. Also, your brake caliper/pads will swap over.
