El-Cheapo Spray gun?
Discussion in 'The Body Shop' started by Chevy305, Apr 14, 2007.
  1. Chevy305
    Chevy305 6 Lug 14bsf Status Premium Member GMOTM Winner
    Jan 23, 2006
    11,228
    485
    New Hampshire
    So I plan on doing some under coating and rust prevention to my frame next week. I bought Eastwood's 3 step system however, I bought an extra quart of the chassis black top coat which I though would be brush on, but its spray on.
    I know nothing about spray guns but I hear that you get what you pay for... So what should I use? This is most likely going to be a 1 time use type deal here.
  2. Thunder
    Thunder 3/4 ton status
    Jul 20, 2000
    8,946
    Northeast Nevada
    I have an El Cheapo I bought at Checker for 12.00. It works fine. If you are just going to use it a few times the cheap ones work ok. They just wear out fast. If you are goiing to do a lot of painting get a good gun.
    For the job you are going to do a cheap gun will work fine
    Just make sure your air compressor has enough CFM to operate the gun.
  3. Chevy305
    Jan 23, 2006
    11,228
    485
    New Hampshire
    I'm not too worried about my air compressor, its pretty big.
    But a spray gun for $12 sounds right up my alley :D
  4. blazindorito
    blazindorito 1/2 ton status
    Nov 25, 2003
    2,047
    Southern California
    HARBOR FREIGHT! I bought one last year to paint my trailer with textured rustoleum and it worked like a $200 gun.
  5. chalet2506
    chalet2506 1/2 ton status Premium Member
    May 9, 2006
    4,931
    Skeddadlin
    I bought the TEKZ 2 gun set from Pepboys for $49.99. It worked well the one time that I've used it.
  6. AZ79K5Project
    AZ79K5Project 1/2 ton status
    Jan 15, 2006
    2,082
    Arizona
  7. Chevy305
    Jan 23, 2006
    11,228
    485
    New Hampshire
    Thanks for all the replies! It turns out that I did not need to break open the quart size spray on Chassis Black while doing my rear 1/2 of the frame. So I'm good for now but I will need one to do the front 1/2 of the frame.
  8. Citizen Rider
    Citizen Rider 1/2 ton status
    May 5, 2005
    1,415
    Plano, Texas
    I painted my blazer with the $20 gravity feed kit from harbor frieght. Also painted my buddies ford with it. Both came out great. It came with a large gun and a touch up gun, filters, tools, everything.
