Eldo caliper casting number question
Discussion in 'The Garage' started by Muddytazz, Dec 1, 2003.
  1. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    Is there way to tell by the casting numbers on the calipers which years they came from? I just got mine in the mail today and wanna make sure i didn't get took. The look like the correct ones from the pics i've seen, just double checking. Any help is great /forums/images/graemlins/thumb.gif
  2. 45acp
    45acp 1/2 ton status
    Jan 3, 2001
    695
    Tucson, Arizona
    Re: Eldo calipers question
    Jeff, If the inside section of the caliper measures 2.5" across and has the e-brake shaft on the inside/backside then you have the correct ones. The newer ones are designed for thinner rotors. Bill
  3. Muddytazz
    Jun 30, 2002
    20,073
    Salem, Or.
    /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif
    Thank you Bill
    I just got my set of caddy calipers for $35 shipped to my door complete with levers and return springs
  4. chulisohombre
    chulisohombre 1/2 ton status
    Apr 11, 2002
    4,141
    14
    Bangor,Pa
    man you got a deal.i got mine bare for 85 appiece
  5. 4X4HIGH
    Dec 14, 2001
    22,063
    70
    Pleasanton, CA.
    The fleetwood and seville caliper castings are the same as the eldorado castings but the piston is different. To measure only the opening of the casting won't tell you anything. You need to measure the opening between the piston and the caliper and make sure it will clear the larger rotor as you stated.
  6. Muddytazz
    Jun 30, 2002
    20,073
    Salem, Or.
    I know its a bad pic, but can anyone tell by just looking at these?
