eldorado caliper, how to retract piston?
Discussion in 'The Garage' started by Jason4x4, Apr 2, 2007.
  1. Jason4x4
    Jason4x4 1/2 ton status
    Nov 5, 2006
    4,505
    6
    Chandler, AZ
    How do you push the piston in on the eldorado caliper. Do you screw in the piston, if so which way? do you use a 9/16 wrench on the stud sticking out? I dunno, but now I get to get one warrantied at autozone, the stupid thing is leaking at the parking brake bolt.
  2. 4X4HIGH
    Dec 14, 2001
    22,060
    69
    Pleasanton, CA.
    There is a tool used for screwing the piston back in. I find it easier to remove the e-brake bracket and then you can gently compress the piston back in. Having the bracket removed allows the e-brake shaft to rotate freely so the piston can be retracted.
  3. jms
    jms 1/2 ton status Author
    Jan 24, 2001
    1,683
    In my experience, it's not the one carried by most parts stores for disk brake service. I've tried rotating the piston and it was a PITA.
    You have the ones with the Seville-style bracket on the caliper, right? I've just unbolted the lever when pushing the piston back in.
  4. bp71k5
    bp71k5 3/4 ton status Premium Member
    Mar 31, 2006
    6,236
    284
    San Jose, California
    A big c-clamp has always worked for me. You can also try prying it in with a prybar /big screwdriver. Just make sure your master cylinder isn't full when you do it or it will overflow. :)
  5. cbbr
    Jul 17, 2004
    14,681
    High velocity, Low altitude
    That won't damage it?
  6. 4xcrazy
    4xcrazy 3/4 ton status
    Oct 31, 2003
    9,471
    5
    Olympia/Lacey, Washington
    it needs to be turned back in, you will damage it by pushing/forcing it in...
    I have always just used some big channel lock pliers, grab the lip of the pistin, and turn it, it goes in.
  7. bp71k5
    Mar 31, 2006
    6,236
    284
    Hmm, maybe it turned as I was compressing it on it's own. I guess I should check if there's any damage, but it seems to be working ok.
