Eldorado caliper problem
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Casey 86K5, Jan 24, 2001.
  1. Casey 86K5
    Casey 86K5 1/2 ton status
    119
    Brownsburg, Indiana
    Im trying to finish up my 14 bolt FF disc brake conversion, but I am having a problem getting the piston on the caliper to go all the way back in. What kind of tool is needed to do this? I have tried the local parts stores but the idiots at the counter dont know what I am talking about. Somebody please help me out on this, I need to get my K5 back on the road!
    thanks
    Casey 86K5 [​IMG]
    <font color=red> -'86 K-5 350/700-R4/14 bolt rear/10-bolt front </font color=red>
    <A target="_blank" HREF=http://86blazer.coloradok5.com>http://86blazer.coloradok5.com</A>
  2. dyeager535
    26,982
    191
    Is it out further than when you replace pads? If its anything like the front disks on the half tons, either hand pressure, (kinda hard sometimes) or a big C clamp slowly cranked down will do it. On your app, not sure if you can fit something like that in there.
    Dorian
    My K5 and Chev/Olds tech/links page: <A target="_blank" HREF=http://yeagerd.home.mindspring.com/index2.html>http://yeagerd.home.mindspring.com/index2.html</A>
  3. Mudzer
    Mudzer 1/2 ton status Author
    3,639
    Missouri
    Ok, first of all, be careful you do not damage the bellows like <font color=blue>Shawn</font color=blue> did [​IMG], anyway, you can turn the calipers down by hand. You will have to remove the lever (not talking about the bracket, remove it too) from the caliper by taking the nut off. Next, you will push in on the piston, or you can use the lever as a wrench and turn it. You will notice the piston will move when you turn the lever. Next, make sure the piston is in far enough, and replace the lever in the fully open position (E-Brake OFF) (against the lever stop) because if you put it in the position where the lever would be when the E-brake is ON, you would then tighten the caliper more when you install the e-brake cable. Email me if this works.
    Mudzer 1978/91 K5
    <font color=blue>www.mudzer.coloradoK5.com</font color=blue>
  4. TX Mudder
    TX Mudder 1/2 ton status
    Jul 10, 2000
    2,514
    Houston
    The other solution is to buy $12 GM calipers and forget about it.
    -- Mike (getting it inspected is always fun)
