Elec. rear window question.
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by BLzr4x4ngkid, May 9, 2001.
  1. BLzr4x4ngkid
    BLzr4x4ngkid 1/2 ton status
    Feb 18, 2000
    703
    Wichita, KS
    I have a problem. My rear window wouldn't go all the way down and then wouldn't go back up. Then I tried it again and it moved like the motor wasn't working right. When I got to work, I got out and tried it with the key........it went up like normal. My supervisor at work said it could be the ground or a loose wire. He's had many Blazers in the past with the same problem. I know the motor isn't bad, because it's like 2 months old. I'd like to be able to roll it down sometime soon. Thanks.
    "Don't hit me with them negative waves so early in the morning." Odd Ball--Kelly's Hereos
  2. rich'90
    rich'90 1/2 ton status
    Feb 27, 2000
    159
    Savannah, GA
    Maybe came off the track? I replaced my motor not too long ago and after about a month it would not go all the way down. Got back in there and found a bracket was binding it up.
    Good luck
    Go heavy or Go home[​IMG]
  3. Brian 89KBlazer
    Brian 89KBlazer 1/2 ton status
    779
    Ontario, Canada
    Check the kill switch on the driver's side latch too. Often, that causes spurratic (sp?) movement of the window.
    Brian
    89KBlazer
