Elec. Tailgate Windows
Discussion in 'The Garage' started by BamBamblazer, Dec 31, 2002.
  1. BamBamblazer
    BamBamblazer 1/2 ton status
    Jun 24, 2002
    486
    McCordsville, Indiana
    I have an electric window on my 86 k5 that has not worked since i got it. I finally dug into it and figured out that the cable was bad. So i replaced the cable and it worked fine with the exception of it wouldnt go down if i tried it with the key. Then it wouldnt go at all from the switch or the key. So i used the drill to get it up and now it will go up, but Now it wont go down with the key or the switch, I am lost. Anything you guys have experienced or is my blazer just posesed by the window devil?????
    /forums/images/graemlins/k5.gif
  2. Mreetz
    Mreetz 1/2 ton status
    Jun 26, 2001
    1,282
    Subs of Denver, Colorado
    I've had this problem before too. I think its in the swtich that keeps your window from opening when the gate is down.
  3. BamBamblazer
    Jun 24, 2002
    486
    The gate is up and the window wont go down is the problem. It worked before but now it has quit????
  4. Mreetz
    Jun 26, 2001
    1,282
    Yea, I think that switch gets stuck somehow. I had taken the motor out replaced and checked the old motor to find out it wasn't the motor at all. Put it back together and it just worked!
  5. Cmoe
    Cmoe 1/2 ton status
    Feb 19, 2000
    2,884
    Mesa,AZ
    There is a safety switch on the drivers side of the tailgate. Some people have just used a jumper to make the conection. may want to see if that is attached or not if it isn't it won't work. Are your still getting power to the rear window motor? May have only blown a fuse.
  6. BamBamblazer
    Jun 24, 2002
    486
    Yes i still have power to the window (it will go up) it just wont go down.
  7. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    If you take the key part out and take it apart and clean the contacts, should work fine. they are copper contacts and get corroded pretty easily. worked for me /forums/images/graemlins/grin.gif
