Electric Choke on an older block?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Blazer_Boy, Dec 24, 2001.
  1. Blazer_Boy
    Blazer_Boy 1/2 ton status
    Dec 16, 2000
    1,669
    Sioux City, IA, USA
    Whats it take to do this. I've got a 350 4-bolt out of '76 truck on the stand and was wondering what it would take to get it to work with the electric choke in my '83. Will that little sender by the oil filter bolt in or do I need a toggle switch?
    <a target="_blank" href=http://www.geocities.com/bigkern76>The Blazer Boy Page</a>
  2. dyeager535
    26,976
    I've never tried to retrofit one of the elctric chokes, but as long as you can get that fitting into a tapped hole that sees oil pressure, you will be ok. You might even run a T off of the oil pressure sender, if it will fit, and is adaptable. All the switch for the choke needs is oil pressure IIRC.
    Dorian
    My tech/links page: <a target="_blank" href=http://www.dorianyeager.com/index2.html>www.dorianyeager.com/index2.html</a>
    Why insist on counting when the ring gear has the tooth counts stamped in?
  3. Blazer_Boy
    Dec 16, 2000
    1,669
    Sioux City, IA, USA
    Thanks man. I've been out at my uncle's tearing down 4-bolt mains (done three so far)and just read this. The last one I tore apart is the best and will be using that. I got to looking and there's a little plug up by the filter where the sender is supposed to go. I still have to investigate it a little more though. I like the pressure sender idea, I'll do that if that plug is the wrong deal.
