Electric choke problems, Q-jet....
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Ben Malinski, Dec 1, 2002.
  1. Ben Malinski
    Ben Malinski Guest
    Any ideas? Started up the truck this morning and like every morning, it dies. I'm tired of farting around with this. Each day I have to adjust it.... however, that is not the problem. The oil light came on. When I disconected the choke wire, the light goes out! What gives? Now the strange thing is that the oil light unit is NOT hooked up! Nor are the other gauges. Cut them all out over the summer waiting to install new gauges. Anyway, why would the electric choke light come on!? The fuse is good. 20 amp. Nothing else connected to it. This never happen before. When I remove the three screws holding the choke on the housing and remove the choke with the hot wire attached, the light also goes out. Connect it to the housing, it's on. Ideas? Thanks!
