Electric choke question
Discussion in 'The Garage' started by sickquad, Jan 5, 2005.
  1. sickquad
    sickquad 1/2 ton status
    Jul 23, 2003
    785
    Ma
    I have a stupid question. Been trying to tune my carb. It is a edelbrock 600cfm with an electric choke and is less than a year old.
    I don't think my choke is acting correctly.
    My question is in the electric choke circuit. It has switched power going into the choke, I checked with a voltmeter. Now on the ground connection I'm not seeing any power going out. If the circuit is working correctly shouldn't I see something on the ground side of the choke circuit. I disconnected the ground and grounded it to the frame with my voltmeter and got nothing.
    Any ideas
    If I'm just being stupid feel free to let me know
    -chris
  2. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    You should only get a reading from the choke ground if your testing it WHILE the choke is on
  3. sickquad
    Jul 23, 2003
    785
    Ma
    I'm testing it with the key on and I know there is power going in.
  4. Mastiff
    Mastiff 1/2 ton status Premium Member
    Jul 21, 2002
    2,755
    48
    Tucson, AZ
    I'm not so sure about the Edelbrock, but the Q-jet just grounded through the carb body. Also, on my 83 there was only choke power when there was oil pressure I believe (went through the oil pressure switch).
    I doubt that was helpful, but FWIW.
  5. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    yah these aftermarket electric chokes have ground and hot spades, two, they dotn self ground to carb body like roch and carter electric chokes do
    you wont see any current flow at ground wire just by touching it with tester, but you may see a little if you put tester in series between the wire and the engine or neg post on battery
    with key on, with hot connected to choke
    you hjave to be IN the circuit,
    not at it to see current flow
    but youre wasting brains anyways, the wire is grounded so thats it, its fine,
    make sure it is though
    when it is then youre done
    choke should be working, key on
    if not then its junk
    good luck
  6. chevy_muscle
    chevy_muscle 1/2 ton status
    Mar 16, 2004
    103
    Murphy, tx
    R72K5,
    I think there is a little confusion,..... he's using a Volt meter and not a current meter.
  7. RustBuket
    RustBuket 1/2 ton status
    Feb 21, 2003
    1,618
    Saskatchewan, Canada
    If there is current flowing in then there is current flowing out. Thats the end of the story. Its working.
