Electric doors??
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by nvrenuf, May 22, 2002.
  1. nvrenuf
    Jan 7, 2002
    13,085
    251
    Mobile, Al.
    Can I change electric doors to manual? Both window motors are bad so I would rather replace it all with manual regulators.
  2. fulltopblazer
    fulltopblazer 1/2 ton status
    Aug 1, 2001
    484
    Altus,Oklahoma 73521
    You can no problem aslong as your doors are newer than '77 thats when they started power windows .........wait your wanting to convert to non power right.....no problem doors are the same everything bolts through the same holes
  3. nvrenuf
    Jan 7, 2002
    13,085
    251
    Mobile, Al.
    GREAT!! That's what I wanted to hear! The doors are '91 model so it sounds like it should go smoothly.
    Thanks for the info!
  4. Michael
    Michael 1/2 ton status
    1,576
    Sherman, Texas
    Hey John, I am interested in your power window guts if ya wanna part with 'em cheap. Let me know, please.
  5. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    Last time I bought one, a power window motor cost about $45 at Autozone. It should be good for at least another 10 years. /forums/images/icons/cool.gif You'll need to swap the interior trim on the doors if you want to go to manual windows, unless you want to leave the power switches on there too. /forums/images/icons/wink.gif
  6. nvrenuf
    Jan 7, 2002
    13,085
    251
    Mobile, Al.
    Wow, I just assumed #1 - that the motors were more expensive and #2 - that the manual window crank would cover the opening on the door panel. I don't want to change the door panel because it has the power mirror switch (keeping those, they are cool!). I may just fix the window motors.
    Michael, if I don't make changes I'll let you know.
    Thanks for the info!!
  7. fulltopblazer
    Aug 1, 2001
    484
    You can use different motors besides the chevy p/u ones. I replaced the ones in a suburban I use to have with ones out of a grand am because they were alot faster. It was a direct bolt in I'm not sure of the part # we (glass shops) refer to them as pancake motors because they are nearly flat and I think they are a whole lot less than $45.00 like half that much. Becareful though alot of power regulators are spring loaded to assit the motor and when you remove the motor it releases the regultor and will take a finger off if your not carefull. I normally clamp the regulator arm in a vise before I remove the motor. Hope this helps
  8. nvrenuf
    Jan 7, 2002
    13,085
    251
    Mobile, Al.
    That is a tremendous help! Thanks alot!!
