Electric Engine water pump
Discussion in 'The Garage' started by ks2krpt, Aug 22, 2003.
  1. ks2krpt
    ks2krpt Registered Member
    Mar 6, 2003
    47
    Adirondack Mts, NY
    I am trying to find a generic electric water pump that will mount in series with the radiator hose with 1.5" connections. Everything I find is for direct OEM replacement. Does anyone have a lead on a pump like I described above.
    Paul
  2. DPI
    DPI 1/2 ton status
    Jun 22, 2000
    2,792
    In the Burbs close to Tulsa, OK
    This may or may not work, but it is remote mounted. It can use 1.25" hose or 3/4 NPT.
    web page
  3. dyeager535
    26,976
    Yeah, what about teeing something like the above pump into a heater hose line?
    Have it "suck" water from the block, and force it into the radiator, given that you have a radiator with a heater hose nipple on it.
    Might have a problem when the engine water pump is turning, but I'd *guess* most electric water pumps don't easily freeflow when turned off.
  4. ks2krpt
    Mar 6, 2003
    47
    Adirondack Mts, NY
    Thank You, that pump will be great for my application. Will order it Monday. Appreciate your help
    Paul
  5. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    mind if I ask your game plan? I'm picturing puting a radiator in the back of a vehicle and using an auxillary pump for better flow.
  6. ks2krpt
    Mar 6, 2003
    47
    Adirondack Mts, NY
    Sled Dog....Nope
    I hate to admit it, but I bought a Chineese Diesel 24 KW Generator. It was a price thing, I knew better....But.
    Its been nothing but trouble, oil and water leaks, injector leaks. Today we had a power failure and I cranked it up and heard a terrible BANG!! the water pump blew. The impeller fragmented and took out the bearings before I could shut it down. I called the importer, NO PROBLEM....I can order a new water pump from China and it will be here within 3 to 4 months ha ha ha ha...... So, I have welded shut the drive opening. I am going to use the external electric water pump and a electric radiator fan....SCREW THEM. When I can afford it, this thing is history. WIll get a Onan or Cat and be done with the problems. THANKS eveyone for your help. Imports form the Pacific Rim is JUNK !
    Paul
  7. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    Paul
    [/ QUOTE ] I think you've got many people that agree around here. I agree on everything except ATVs, Motorcycles, and Dirt Bikes but even then they are produced in America most of the time so thats fine.
