electric fan does it work?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by sting, Mar 19, 2001.
  1. sting
    sting Registered Member
    Aug 14, 2000
    31
    Will a electric fan help cool my motor in the summer i have a new 4 core radaitor...also will it help
    the a.c. in the summer...and what type of fan 10 blade?...should it be mounted in front or behind
    the radiator...
  2. Burt4x4
    Burt4x4 3/4 ton status
    6,854
    California (Modesto area)
    I use the Flex-A-Lite BlackMagic M150 electric on my 350 with a 3row. I have 0 cooling issues. I am electric only too! Even in the CentralValley heat during summer at 105 cruzin down a trail or fire road my rig never gets above 200. On the hwy in the summer it runs at 190-195. The M150 was the highest rated for cfm 2800cfm for a single puller is good!
    It works and i'm likin it!
    <A target="_blank" HREF=http://www.burt4x4.coloradok5.com>http://www.burt4x4.coloradok5.com</A>
  3. 80blazer
    80blazer Registered Member
    Mar 4, 2001
    41
    glendale arizona
    Burt: do you have a shut off switch for water crossings and such. What do think about running both, I wheel mostly desert. Thank you Jeff 80blazer
    Its time to lock them in!
  4. Burt4x4
    6,854
    Yes I do shut it off when in water or goin down the hwy.
    I originally was going to run both and I did for almost a year and a half. I was oly turning the electric on during summer on the trails. So I wanted to test with out the mecanical fan and took it off. I don't plan on putting the mecanical fan back on but i do carry it with me on long trail rides as a backup just incase the electric fails.
