Electric Fan install complete! PICS right this way ------------>
Discussion in 'The Garage' started by jakeslim, Jun 27, 2004.
  1. jakeslim
    jakeslim 1/2 ton status
    Sep 18, 2002
    2,686
    Napa, CA
    Well fan is all the way installed now. Slow kicks in at 180, fast kicks in at 200. Cools like a charm. Yesterday in Napa,CA was very hot. I drove around in city traffic for a long time and not once did I pass 200, always dipping cooler once the second speed kicked in.
    The beauty of this fan selection is that it fills the stock shroud so I kept it, thereby keeping that "stock" look.
    REMEMBER, this fan cost me $9.99 at pic n pull!
    The thermostats(two) cost me 60 bucks total, + a couple of bucks for wire at the local hardware. Mounting to the stock shroud required a bit of original shroud trimming, but was easy to do.
  2. jac6695
    jac6695 1/2 ton status
    May 2, 2002
    1,860
    Christiansburg, VA
    That is the T-Bird fan, right? What is the diameter of the fan?
  3. hi pinion
    hi pinion 3/4 ton status
    Sep 25, 2003
    5,354
    **PLUMBING THE WORLD**
    Cool deal man!!! /forums/images/graemlins/peace.gif Frees up some more power too /forums/images/graemlins/peace.gif /forums/images/graemlins/thumb.gif
  4. jakeslim
    Sep 18, 2002
    2,686
    Napa, CA
    Yeah, the t-bird fan. Its 18" as measured installed so may be a little off since it was hard to get it exactly and its a two speed with 7 blades(fairly aggressive blade style).
  5. Mudbug1979
    Mudbug1979 1/2 ton status
    Aug 4, 2002
    439
    Monroe,North Carolina
    What year was the Fan off of and was it from a V6 or Super coupe V8? Thanks for the pics, looks good /forums/images/graemlins/waytogo.gif
  6. jakeslim
    Sep 18, 2002
    2,686
    Napa, CA
    to be honest I'm not exactly sure of the year. I believe it was from a 93...maybe 94. Also, since the radiator had been pulled with the fan and set aside by someone else, all I had to do was undo two bolts and done. That being said I did not take a good look at the engine, but i believe it may have been a v8....BUT, that is more of a guess from by memory(if that makes sense). I also picked up a windstar dual fan setup that day, but went with this one because of the more stock look, which i prefer.
  7. unick
    unick 1/2 ton status
    Aug 16, 2003
    4,286
    San Diego Comufornia
    Whats the point of keeping the fan shroud? I know why it would be on for a stock set up but why with the electric? Ill be putting dual escort fans in my K5 soon.
    Nick
  8. sickquad
    sickquad 1/2 ton status
    Jul 23, 2003
    785
    Ma
    That fan is off of a 4.6 V8 T-Bird if I remember correctly.
    -Chris
  9. oldtoyboyd
    oldtoyboyd 1/2 ton status
    Nov 12, 2003
    904
    3
    Leesburg, MS
    what kind of thermostats did you buy
  10. jakeslim
    Sep 18, 2002
    2,686
    Napa, CA
    picked them up at Kragen auto. Advanced has them also. Really easy to set up. I always had read others post about this and it looked complicated, but it is REALLY easy.
    Paul
  11. rjfguitar
    Aug 28, 2002
    9,095
    144
    california
  12. oldtoyboyd
    Nov 12, 2003
    904
    3
    Leesburg, MS
    I had a double side by side set of flexalite fans on my 73 that mounted to the radiator. They tore the fins and one of the tubes of my radiator. I can buy new ford winstar double fans for $120 so I think I will use them with some brackets this time. I am looking for a good thermostat that has a sender that threads in the block this time, if anybody has used these types post up with what works best.
  13. santana
    santana 1/2 ton status
    Jan 11, 2003
    1,483
    Mesa Arizona
    Excuse my French fellas but aren't T-Pigeons RWD? /forums/images/graemlins/thinking.gif I was at Ecology yesterday and all the T-Chickens I saw out there are RWD, but I did grab a pair of dual late model Taurus fans for $25. Checked the #'s out and turns out they're the same as the Windstar ones /forums/images/graemlins/thumb.gif. Gonna try and get them in by this weekend and I'll show ya pics. /forums/images/graemlins/peace.gif
  14. sickquad
    Jul 23, 2003
    785
    Ma
    RJF, you seem like a knowledgable guy, what made you decide on those fans? There are definitely cheaper ways of installing electric fans. Is it solely for the bling affect? Just asking because I am doing electric fans real soon.
    Any pics of your installation?
    -Chris
  15. 88Silverado
    88Silverado 1/2 ton status
    Mar 13, 2003
    2,664
    Quartz Hill, So. Cal
    I like that setup....looks pretty clean.
    I have an extra set of winstar fans (bought a spare set when I did the install on my ElCamino) so ill go the winstar route. Either setup should work fine due to the full shrouds. On my 71, I use a thermo switch in the block to turn them on and they are also wired to my Air switch so they turn on when the air is on.
    Nice setup /forums/images/graemlins/waytogo.gif
  16. jakeslim
    Sep 18, 2002
    2,686
    Napa, CA
    Just got back from towing my "new" 1969 k5 with my 77 k5....what a site! The temps maintained throughout the trip under load so I'm quite pleased.
    later,
    Paul
  17. hi pinion
    Sep 25, 2003
    5,354
    /forums/images/graemlins/mad.gif /forums/images/graemlins/rotfl.gif
  18. rjfguitar
    Aug 28, 2002
    9,095
    144
    california
    -Chris
    [/ QUOTE ]The bling factor on fans? /forums/images/graemlins/dunno.gif /forums/images/graemlins/screwy.gif /forums/images/graemlins/histerical.gif
    I chose that setup because it is a complete kit down to the electrical connections. Everything you could possibly need to do the install is there. I wasn't in the mood to dink around trying to find used fans that I hoped would pull enough air and try to gather up all the electrical parts. Easy for some people but I drive my K5 everyday and can't afford the downtime....I got the fans in the morning and 3 and a half hours later the /forums/images/graemlins/k5.gif was back on the road with electric fans. /forums/images/graemlins/waytogo.gif
    Also those flexalite fans pull some SERIOUS air volume and they look very HD and will probably last trouble free for a loooonnngggg time and if something does go wrong I have a 5 year warranty! /forums/images/graemlins/peace.gif /forums/images/graemlins/bow.gif They are wired in with my A/C and come on as soon as the compressor is engaged not to mention the A/C is probably 10-15* colder in town driving. I have a manual switch also and the thermostat works flawlessly. They vary from %60 to %100 depending on the coolant temp and only come on at %100 when needed which really helps save a few amps, cut down on noise, and help them last longer.
    I have considered trying to hunt for windstar fans or whatever is supposed to be good but after seeing these new fans from flex a lite I decided that was what I wanted and I am glad I got them because it is a very clean and powerfull setup, way better than what I could try to match with trying to piece stuff together. No pics currently but will get some. /forums/images/graemlins/waytogo.gif
  19. Cmoe
    Cmoe 1/2 ton status
    Feb 19, 2000
    2,884
    Mesa,AZ
    Cool Jerry you found some..... Do we still need to draw it up a shrould? or have you started building one?
    We saw you on the corner of Alma & Gaudalupe @ 6:00 last night, were you just getting home from work?
  20. santana
    Jan 11, 2003
    1,483
    Mesa Arizona
    Yup, I was on my way, /forums/images/graemlins/woot.gif.. I did get the shroud made, also picked up a wiring kit for the fans which include relay, AC hook up and T-stat. /forums/images/graemlins/thumb.gif
