Electric Fan start temp question **Updated question**
Discussion in 'The Garage' started by opfor2, Sep 19, 2005.
  1. opfor2
    opfor2 1/2 ton status
    Oct 28, 2002
    375
    Ventura County, CA
    Well I finnaly did it. I bought a new Flex-a-lite # 292 electric fan for my stock 90 K-5 Blazer with TBI-350 with a 195' thermostat. My question is at what temp did you adjust your adjustable fan controler to turn the fan on? What would be the "Ideal" turn on turn off temp?
    thanks
    Dan
  2. 4X4HIGH
    Dec 14, 2001
    22,063
    71
    Pleasanton, CA.
    That question is dependent on what degree temperature sensor is being used.
  3. dirtwarrior17
    dirtwarrior17 Banned
    May 14, 2004
    1,820
    Redding, CA
    yup. they go anywhere from 160 on up.
  4. highrlr
    highrlr 1/2 ton status
    Nov 29, 2004
    302
    Bismarck, ND
    My flex-alite is adjustable to whatever temp you want it to come on at. I have mine set around 190, any lower than that and it seemed to kick in and out ALOT!
  5. opfor2
    Oct 28, 2002
    375
    Ventura County, CA
    True that, mine will come with the new and improved adustable sensor, so i'm trying to get an idea as to were to set it. I downloaded the installation sheet and it really dosen't give any information as to what the "Ideal" setting would be.
    Dan..
  6. dyeager535
    26,982
    191
    As an example, GM set the fans to come on at about 25* above the thermostat temp.
    I assume part of their cooling strategy is based on how efficient the cooling system is. Trying to keep a vehicle with a 195* stat at 195* at idle is possible if the cooling system is efficient, but it's going to be much harder on the cooling system as a whole to keep it at 195* than it is at a somewhat higher temp.
  7. 89GMCSuburban
    89GMCSuburban 1/2 ton status
    Nov 15, 2001
    3,005
    Thornton, CO
    Run the truck. Feel the upper hose. When it gets hot (thermostat opened), turn the knob till the fan turns on. Voila.
  8. Smitty
    Smitty 1/2 ton status
    Sep 1, 2000
    999
    Crestview, FL
    I'm running a 180 thermostat and have the controller for the fan set to turn on at 195. Seems to be working without any problems.
