electric fan wiring ( need ignition on wire)
Discussion in 'The Garage' started by wraenking, Apr 8, 2006.
  1. wraenking
    wraenking 1/2 ton status
    Apr 30, 2003
    1,493
    Toms River, NJ
    what can i use in the engine bay to hho into ignition on? i have the wire thats going to the tach but i dont know if i splice into that if it will screw up my tach. i really dont want to splice in near the dizy, looking for something closer to the core support!
    thanks
    tom
  2. onetonbb74
    onetonbb74 1/2 ton status
    Dec 1, 2005
    2,083
    Campbell, CA
    the tach wire is a negative and the ignition is the hot even on HEI setups. Id run the wire from the battery thru a swithch on your dash then back to the fan. Or run the wire from the ignition port off the fuse panel to the fan directly. There is no ignition hot wires on the core support.
  3. dyeager535
    26,975
    Don't splice anything, that's why the fuse panel has all the empty slots across the top of it.
    You're just running a light gauge wire assuming you are setting up some sort of relay system, so it's not going to be hard to run the wire.
  4. wraenking
    Apr 30, 2003
    1,493
    Toms River, NJ
    yup, wired it right to the fuse panel. ill post a thread with some pics of the install after the first period of the devils game
    thanks guys
  5. 79Jimmy
    79Jimmy 1/2 ton status
    May 10, 2000
    214
    Richmond BC, Canada
    "after the first period of the devils game" I like your priorities.:D :D
    James
  6. wraenking
    Apr 30, 2003
    1,493
    Toms River, NJ
    up 1 nothing. important game tonight. both needing the win to break away from the other. whats makes hockey so damn exciting!!
