Electric Fan?
Discussion in 'The Garage' started by prossett, Apr 22, 2006.
  1. prossett
    prossett 1/2 ton status
    Sep 29, 2005
    165
    United Arab Emirates
    What are the realistic gains from replacing the stock mechanical radiator fan with an electric one?
    I have no overheating problems, despite the extreme temperatures out here, and I also have dual electric fans in front of the rad controlled manually from a switch in the cab, so it's purely HP gains I'm looking for. I run a 1983 350 Jimmy.
    Any tips on moving to an electric main fan?
  2. ProJunkRacing
    ProJunkRacing 1/2 ton status
    Jun 20, 2005
    1,229
    FrankFort IL
    well from what you are saying you have dual electric fans in front of the radiator i am guessing that "push air over it since they would be facing the radiator. now you are contemplating replacing the main clutch fan with another setup ?.... why excately just for more power i guess if you added more fans you get more air but i dont thin k it will help much since you already have 2 imho
  3. 1985_K5_Silverado
    1985_K5_Silverado 1/2 ton status
    Dec 21, 2005
    984
    Corn Country
    Without the electric fans installed, just using the stock clutch fan setup, did you have any overheating problems?
  4. dyeager535
    26,981
    Similar sentiment. If the stock clutch fan is doing the job, ditch the electrics. If you want to try electric only, pull the clutch fan off and see if they will do as good of a job.
    The only power numbers I've seen for a clutch fan are -5HP but I suspect that is with the clutch "unlocked".
    The stock fan doesn't draw nearly enough power to notice in a normal vehicle. If you measure time in the 1/4 mile, or strap it to a dyno, perhaps, but for most (here) electric fans are used so they can be shut off in deep water fording.
  5. greg mgm
    greg mgm 1/2 ton status
    Apr 6, 2005
    152
    Pine Cove (near Idyllwild) CA
    I just pulled off the twin fans from my 78 truck, and went back to belt driven. The elec fans couldnt keep up when towing, or going up a big grade. Freeways, slow moving traffic, crawling, and daily driving they worked great, and I did feel a bit of an improvement in the power. If you're just looking for HP gains, the elect fans "may" help, but just dont do heavy towing with them.....Anyone want to buy some elec fans??? (J/ K)
  6. prossett
    Sep 29, 2005
    165
    Good posts, thanks.
    The electric fans up front only go on when I need to kick down the temperature, usually when working through deep sand at low speeds for a while. Without them the temperature does keep climbing, but we're talking temperature extremes.
    With my current set-up I don't need extra cooling or more fans, I was just thinking of a power gain. Turns out a +/- 5HP gain doesn't warrant a change over to electric.
    If it were 20HP, I'd consider it.
    Thanks guys!
  7. beastofablaze
    beastofablaze 1/2 ton status
    Apr 4, 2005
    441
    CA
    You might gain 10 or 15 hp but it will be at very high rpm where you will barely need it or notice it.
