electric fan
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by mdm365, Jan 27, 2002.
  1. mdm365
    mdm365 1/2 ton status
    Jul 2, 2001
    536
    mineral wells wv
    I just put in a 350 crate motor in my k5 and I am wanting to put and electric fan my question is push or pull and in side with the engine or out side of the radiator and were should I install the heat switch to turn the fan off and on. thanks for the input. mike from las vegas.
    1977 k5-blazer 4"softride 3.5 in rear dana 44,12 bolt rear,now 350 &,205 t-case,465 trans,new headers and new 2 1/4 inch turbo muffler exaust.
  2. lasvegas
    lasvegas 1/2 ton status
    Feb 27, 2001
    122
    Las Vegas, Nevada
    I sent you a response to your e-mail address on your profile.
  3. BurbinOR
    BurbinOR 3/4 ton status
    5,829
    Oregon
    Might want to do a search on this topic, you'll come up with a TON of responses. I use a factory stock '90 IROC single puller fan in a shroud - with a 406 SBC and a 4 row radiator. No problems at all for me.
    Heat switch probe goes in the radiator towards the top.......pushes through the fins and is secured on the other side. Good idea if you feel it's necessary to put a secondary switch in to kill the fan if you get in deep water/mud.
    ONE TON</font color=blue> <font color=green>TPI'd</font color=green><font color=red> BEAST<font color=red>
  4. lasvegas
    Feb 27, 2001
    122
    Las Vegas, Nevada
    Do you have part numbers and does the fan include the shroud and everything needed or not? thanks
  5. BurbinOR
    5,829
    Oregon
    Sorry Damon, don't have part numbers.............I got it from my engine builder, he gets them from IROC's and Z-28's all the time from a local Firebird/IROC specialty auto recycler. The fan had to be mounted in the shroud with 'L' brackets, simple and effective. You can see what the fan setup looks like on my site, click below and check out I believe the Steering Box Brace page, shows the view from the bottom.
