Electric fuel pump backup...series or parallel with mech. one?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by TX Mudder, Oct 25, 2004.
  1. TX Mudder
    TX Mudder 1/2 ton status
    Jul 10, 2000
    2,514
    Houston
    I have a Holley elecric fuel pump from another project and don't need it for the other project anymore, so I thought I'd hook it up as a backup.
    DO I have to bypass the mechanical one? If I activate the electric one, will it pump gas THROUGH the mechanical one? I know the electric one will not allow gas to go through it if it is off.
    Anyone know? It would be so much easier if it does do this, as I want to put the fuel pump by the tank and don't want to have to run an extra line all the way up to the carb.
  2. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    I don't think the mech pump will allow gas to pass threw it when it is not pumping. I would just splice into the fuel line after the mech pump and connect the elec. on a line that bypasses the mech.
    Harley
  3. mouse
    mouse 1/2 ton status
    Nov 10, 2003
    1,448
    Great Falls Mt
    The real gain from an electric fuel pump is by eliminating the parasitic loss the mechanical pump causes on the timing gear/cam. If you use the electric pump buy a block off plate - couple of bucks- and save a few horsepower!
