Electric Fuel pump question
Discussion in 'The Garage' started by Joshinator, Dec 14, 2005.
  1. Joshinator
    Joshinator Registered Member
    Jan 19, 2005
    58
    Sulphur Louisiana
    Ive got a 96 Vortec 350 in my K5. When you turn the ignition on, the fuel pump runs like normal, for about 6 seconds. Now, its also running for the same 6 seconds when you turn the ignition off. Anyone have any ideas why its running with the ignitioin off?
  2. 4X4HIGH
    Dec 14, 2001
    22,063
    70
    Pleasanton, CA.
    AFAIK it is common for the pump to run a few seconds before and after the engine has started.
  3. sweetk30
    Nov 1, 2004
    25,548
    543
    horseheads , ny 14845
    my stock 96 c3500 with same motor does this also. :confused:
  4. gauder
    gauder Banned
    Aug 26, 2005
    1,613
    done
    It's to keep pressure in the line I believe.
  5. Joshinator
    Jan 19, 2005
    58
    Sulphur Louisiana
    Y'all are right!!
    Yeap, it is supposed to do it. Had to do some research to find out. I guess since ive moved the tank i can just hear it better than before. Thanks for the reply's fella's, much appreciated.
