Electric fuel pump replacement, how do I get the strainer through the hole?
Discussion in 'The Garage' started by divorced, Mar 25, 2006.
  1. divorced
    divorced 3/4 ton status
    Jul 20, 2004
    5,115
    1996 K1500, Vortec 350
    So I'm replacing the fuel pump in my girlfriend's truck, and I got to the point of pulling the sending unit/fuel pump from the tank. How am I supposed to get this thing throught the hole? The screen on the bottom can't make it through. I don't want to screw up the sending unit because it's close to $300 to replace it. I think I know what to do to get it out, but I'll let someone tell me for sure.
    And also, the new pump is a "turbine" pump and it says it doesn't use pulsators and to throw them away. What's a pulsator?
  2. 1979jimmy350
    1979jimmy350 1/2 ton status
    Mar 24, 2004
    3,069
    Ann Arbor Mi
    the screen is flexible and can be bent to get through the hole
  3. divorced
    Jul 20, 2004
    5,115
    Cool, that's what I was thinking, but just wanted to check for sure.
    Any idea on the pulsators? I guess I'll go yank it out and check out what parts don't look like they're needed anymore. The new pump come with a bunch of clamps and other assorted crap... it looks like fun.
  4. 1979jimmy350
    Mar 24, 2004
    3,069
    Ann Arbor Mi
    the pulsator is right above the pump. one end goes on the fule pump and the other on the sending unit
  5. goldwing2000
    goldwing2000 Guest
    Put some hair around it? :whistle:
  6. Bushido
    Bushido Registered Member
    Jan 25, 2006
    38
    Hawaii
    Beside putting hair around it.:haha: ----You can remove it from the pump.It's only slid on with a little barb.You should think about replacing it as well with the pump.
  7. goldwing2000
    goldwing2000 Guest
    You DEFINITELY DEFINITELY DEFINITELY have to replace that screen when you replace the pump!
    Fuel pump manufacturers won't honor the warranty unless you do.
    It's cheap insurance.
  8. divorced
    Jul 20, 2004
    5,115
    Ok... I got the old one out and the new one in. I just need to re-connect all the hoses and wires then *hopefully* start the truck.
    I bought a new screen when I bought the pump, so I'm all good there.
    I found the pulsator. The new pump has a short hose that replaces the pulsator. Thanks 1979jimmy350 for the info.
  9. 4xcrazy
    4xcrazy 3/4 ton status
    Oct 31, 2003
    9,471
    5
    Olympia/Lacey, Washington
    that's good, because I was gonna say,,,spit on it :D
