electric fuel pumps
Discussion in 'The Garage' started by wasted wages, Apr 28, 2004.
  1. wasted wages
    wasted wages 3/4 ton status
    Dec 3, 2003
    9,194
    Dallas Texas
    anyone run an electric fuel pump on their rig ?
    (not the in tank FI type) I have had 2 mallory pumps fail within 2 years. (140 gph) second one is dead now,,,thinking about going to a holley black pump,,, any thoughts or suggestions????? /forums/images/graemlins/dunno.gif /forums/images/graemlins/dunno.gif /forums/images/graemlins/dunno.gif
  2. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    I would suggest you go to the parts store and buy a lifetime warranty pump. My catalogs list a number of universal inline pumps for either EFI or carbs and the pricing isn't bad, either.
  3. marine_enlisted
    marine_enlisted 1/2 ton status
    Sep 29, 2002
    658
    Stafford, VA
    MSD makes fuel pumps as well. I ran one when I first put the Vortec in my rig. It was too loud for my taste. It was a high PSI unit though, maybe the lower pressure ones are a little quieter.
  4. gravdigr
    gravdigr 1/2 ton status
    Apr 15, 2003
    1,129
    Tyrone, PA
    I currently run a electric pulse pump but it will get changed soon. One big thing when running an electric pump people tend to forget is to run a return line to the tank. This keeps fresh gas running through the pump which cools and lubricates it. If you have a 140gph pump on a stock rig using 30gph and no return line odds are the pump is running hot which will shorten it's life.
  5. RingMaster4x4
    RingMaster4x4 1/2 ton status Premium Member
    Mar 4, 2001
    2,049
    Bartlett, Texas
    I have run a Red holley on my blazer for the last 2-3 year with no problems. /forums/images/graemlins/thumb.gif
  6. nvrenuf
    Jan 7, 2002
    13,072
    245
    Mobile, Al.
    I ran a Holley blue pump on my K10 for a few years when TARussell and I were racing it. The pump always worked flawlessly but it was loud.
    If I had it to do again I would run a Barry Grant pump. BG offers one that pushes about 280 gph and it has a provision for a return line. Using a return line will help reduce heat build up and prolong pump life.
    FYI - Most of the time I ran the Holley pump I ran a BG bypass valve that allowed me to have a return line back to the fuel cell.
  7. CyberSniper
    Apr 21, 2003
    2,257
    5
    Chelsea, MI
    I use a Carter street/strip pump and it works pretty well. When I originally bought it a couple years ago it cost me $43.95 from Summit. I think they're in the sixties now...
  8. Can Can
    15,552
    136
    Cochrane, Alberta, Canada
    I've been running the same Carter electric pump on my 84 for the last ten years with absolutely no issues.....
  9. wasted wages
    Dec 3, 2003
    9,194
    Dallas Texas
    I went with the Holley black pump W/ regulator.
    I will be looking into the return line bypass,
    makes sense the pump will not have to run against full pressure all the time,will most likely run cooler.
    Thanks To All /forums/images/graemlins/bow.gif /forums/images/graemlins/bow.gif /forums/images/graemlins/bow.gif /forums/images/graemlins/bow.gif /forums/images/graemlins/bow.gif /forums/images/graemlins/bow.gif
  10. cybrfire
    Dec 15, 2002
    15,139
    565
    Iowa
    I recently switched from a leaky holley to a carter pump. Ten times quieter and it looks less likely to leak.
