electric gurus ...blowing radio fuse
Discussion in 'The Garage' started by bryguy00b, May 14, 2004.
  1. bryguy00b
    bryguy00b 3/4 ton status
    Apr 7, 2002
    5,587
    Rochester, N.Y
    i keep blowin out the fuse for my radio with in like 15 minuts or so of replacing it. im using a 15 amp fuse. there must be a short or something someplace, but im unsure of wear to start lookin.. /forums/images/graemlins/dunno.gif
  2. kazajames56
    kazajames56 Registered Member
    Jun 13, 2003
    28
    Kenner, LA
    Is it the fuse on the back of the radio, or one on one of the lines? If there is a fuse on the yellow wire (constant 12V), it might be blowing the fuse there. On mine, the PO had one on this yellow wire, and everytime I would turn the stereo up, the fuse would blow and shut the stereo off. Just a suggestion... /forums/images/graemlins/1zhelp.gif
    Steven
  3. duece21
    duece21 1/2 ton status
    Jan 18, 2004
    501
    Aurora, CO
    I know mine is wired in w/ the cig lighter on the fuse panel. The lighter when plugged in was causing a dead short and would blow the fuse each time. Could try there, but I don't know if mine was wired that way by the PO. /forums/images/graemlins/dunno.gif
    Good luck.
    Jesse
  4. bryguy00b
    Apr 7, 2002
    5,587
    Rochester, N.Y
    its blowing the fuse labled radio on the fuse block..dunno why though.....
  5. scoutillac
    scoutillac 1/2 ton status
    Feb 24, 2004
    423
    Spokane, Wa.
    Mine was doing some crazy crap like that too. I finally just ran a seperate fuse block for lights and stereo behind the glove box. I just got tired of all the bs. It was easier to just bypass it.
  6. bryguy00b
    Apr 7, 2002
    5,587
    Rochester, N.Y
    could i just wire it right to the battry and run an inline fuse or somethin..
  7. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    Me too. That is my ONLY electrical gremlin. It is the wire itself in mine, I ran a new wire with a seperate fuse also. /forums/images/graemlins/k5.gif
  8. bryguy00b
    Apr 7, 2002
    5,587
    Rochester, N.Y
    what wire is it? im not sure or how to trace it? wear did u run it to?
  9. scoutillac
    Feb 24, 2004
    423
    Spokane, Wa.
    Come off of the batt to your new fuse block. Then there are three main wires. Red to ign.(or a wire in dash not hot unless the key is on). The yellow should be constant hot(run to your new fuse block).Black is ground. Is that simple enough. There might be a diagram on the top or bottom of the deck when you pull it out.
  10. bryguy00b
    Apr 7, 2002
    5,587
    Rochester, N.Y
    i dont wanna have to put another fuse block in just for this thing though, ahh i dunno when i get some free time ill pull it out and see what i can wire up or something lol.
  11. ryanvz1
    ryanvz1 Registered Member
    Jan 20, 2004
    34
    Easy fix, put a bigger fuse in it, like a 30 amp. If it still blows then you got problems.
  12. tomseviltwin
    tomseviltwin 1/2 ton status
    Dec 23, 2001
    2,065
    Utah
    You need a new cigarette lighter. I'll bet you a sixpack /forums/images/graemlins/thumb.gif (No really /forums/images/graemlins/waytogo.gif)
  13. 1-ton
    Apr 17, 2004
    2,880
    159
    Las Vegas, Nevada
    Re: electric gurus ...blowing radio fuse *DELETED*
    Post deleted by 1-ton
  14. bryguy00b
    Apr 7, 2002
    5,587
    Rochester, N.Y
    i dont think putting in a bigger fuse is the right thing to do, u only need a 15..putting in a bigger one would be like ignoring the problem and that could be bad i would think...
    ill check the for the speakers though, the wiring it pretty shitty for them i know that much.
  15. tomseviltwin
    Dec 23, 2001
    2,065
    Utah
    I had this same problem and it was my cig lighter was bad. It's a $2.00 part. Try it.
  16. darkshadow
    darkshadow 1 ton status
    Dec 6, 2003
    12,250
    C-eh-N-eh-D-eh
    yeah it the cig lighter, at the back of the sockit its grouding out, put a new fuse in turn up your radio and smack, the ash tray, youll see it spark so try and prevent it grounding out thats it
