electric or mechanical gauges, which is better
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 8_YOUR_H2, Jul 15, 2000.
  1. 8_YOUR_H2
    8_YOUR_H2 1/2 ton status
    Feb 20, 2000
    2,663
    Iowa
    I am doing a custom gague install in my truck and I think I have heard that mechanical gauges are better (more accurate...what do you all think?
    Brent
  2. Peeetah
    Peeetah Registered Member
    Jul 3, 2000
    97
    Mt. View, CA
    Go Mech.
    From what I understand electrical gauges can give false readings if your electrical system malfunctions, so I would use mech. gauges.
  3. J.R.
    J.R. Guest
    if you can take some pics of how it turns out that would be great.im thinking of replaceing my factory gauges but i want to use the factory location for the new gauges. is that what you are going to do?
    BIGBLOCK MAN
  4. blazer72
    blazer72 1/2 ton status
    Apr 13, 2000
    939
    KCMO
    cheap electrics are bad there readings change with voltage. A good electric gauge like VDO is better than most cheapmechanical one, The best word is to mix them up! I run VDO some are mech. most are electric,
    I understand the jeep thing I drive a BLAZER!!
    Ken
  5. 8_YOUR_H2
    Feb 20, 2000
    2,663
    Iowa
    Yes, I am going to use the stock locations..I have it all planned out, Gotta convince the wife to release the funds. The speedometer will be the most expensive then the tach...but I thing they will be the most difficult to install. Ill keep ya informed on how it goes!
  6. riz
    riz 3/4 ton status
    Mar 7, 2000
    6,026
    Wisconsin
    I think I've read a few guys on here tried installing gauges in the factory locations and didn't have much luck at it.
    L8r,
    .Riz.
  7. '73 K5
    '73 K5 1/2 ton status
    1,763
    Kansas
    Always had trouble in the past with electric and the damn sending unit for oil pressure. So now I have a mechanical gauge and I really like it. No problems.
    '73 K5
    Chevy good...Ford bad
