electric over hydrlic winchs
Discussion in 'The Garage' started by FatBoyBlazer, May 16, 2002.
  1. FatBoyBlazer
    FatBoyBlazer 1/2 ton status
    Feb 22, 2001
    1,508
    Worcester, MA
    would i be able to mount one of these onmy truck, i can get a 8,000 lb one for 200 bucks.......should i do it....it came off of a wrecker
  2. trukman1
    trukman1 1/2 ton status
    Mar 5, 2002
    129
    Ohio
    Without seeing the winch it's difficult for anyone to give you an answer. My personal opinion, it's usually better in the long run, to get something made for your application in the first place. Example, I purchased a PTO winch from a farm truck for $100 then had to spend another $265 for the pto unit and parts to fit my transfer case. Still a good deal but all these "deals" come with their hidden costs. Ultimately, you'll have to make your own final call.
  3. 70~K5
    70~K5 1/2 ton status
    Apr 13, 2002
    2,032
    sillycon valley
    You'll need a pto to drive a hydralic pump and a control valve assembly to control it. But once everything is hooked up you could winch all day as long as the motor is running. Also you'll need a hydralic tank to hold the fluid.
