Electric Razors...
Discussion in 'The Lounge' started by Confedneck79K30, Nov 6, 2006.
  1. Confedneck79K30
    Confedneck79K30 3/4 ton status
    Oct 1, 2006
    5,384
    LA
    ok guys and gals, who here has one??
    and WHY are the replacement heads for my norelco, 4 dollars less than a whole new razor?? i mean, i dont use it that often, my facial hair dont grow that fast so i keep it trimmed and a regular razor on my sideburns, but wtf over?
  2. k20
    k20 3/4 ton status
    Sep 9, 2001
    5,068
    Mineral Springs, NC
    tough it out till the christmas sales. I got a $100 electric for like $12 year before last, its about to need a replacement though, motor makes some weird sounds some mornings
  3. chevyfumes
    chevyfumes Court jester
    Feb 24, 2000
    38,584
    266
    Watch for the muzzleflash!
    Id rather use my straight razor, electric just pulls the hair out...
  4. Confedneck79K30
    Oct 1, 2006
    5,384
    LA
    hell they got a nice norelco for 39.99, and my heads (Set of 3) is 34.50... wtf?
  5. mikey_d05
    mikey_d05 1 ton status GMOTM Winner
    Nov 23, 2004
    10,453
    Minnesota
    Same here, dunno what it is about my facial hair but electrics just rip it out. Although replacement blades aren't exactly cheap these days either...
  6. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    I had a Norelco for 20 years. Finally gave up on it when it needed its 3rd set of batteries. They aren't user-replaceable, and it cost too much to have them replaced. I picked up an $80 Remington foil style razor on Amazon for $30 when they were running a clearance.
    The Remington shaves smoother than the Norelco did, but it has its own problems...
    1) It misses a few whiskers nearly every day. Once they're a tad too long, they don't get cut at all by the foil cutter system. I guess that they don't fit into the holes in the foil properly when longer. So I'm always using the side trimmer to get the long hairs first, THEN shaving. It's more hassle than using the Norelco was.
    2) The foil doesn't last long. One row developed a small hole near the 1-year mark, so I had to buy a new set of foils. Cost something like $23! Ugh! By contrast, my 20-year-old Norelco was still on its original set of heads when it finally gave up. :cool1:
  7. pvfjr
    pvfjr 1/2 ton status
    Feb 10, 2004
    2,425
    Oakridge, OR
    How long did you give it? That's only true in the beginning. I thought the same thing when I first started using mine, but my dad told me to give it time and that my face would get used to it, or "broken in". Sounded insane, but turned out he was right. After 2-3 weeks of daily use, it went fine and was a lot less irritating than a blade. Turns out it was in the instructions too. :doah:
    I've got a basic norelco that I've been using for three years now on a daily basis, haven't even sharpened it. Batteries still last forever, no problems whatsoever. But if I go more than 2 days without shaving, I have to trim it down with the clippers first, otherwise the norelco will pull. That's only if the hair is too long though.
  8. 73k5blazer
    Dec 28, 2001
    4,987
    38
    The Rustbelt
    I use a Norelco elec. I shave my whole head every couple of days. They lastabout 2.5 years before I need to replace it. I tried the foil kind, it sucked. For me at least. I'd have to take 30 passes at a swath of hair before it got it all completely. The norelco just 2-3 passes and it's good.
    I never buy the replacment blades, I find by the time they are worn, the motor is weak, the trimmer is busted, the battery won't hold a charge ....
  9. Col_Sanders
    Col_Sanders 3/4 ton status
    Apr 27, 2005
    5,688
    KFC
    I have a Braun now. It is around 2.5 years old and still works like a champ. This is my 2nd set of foils but I changed the 1st at the 1 year mark like the manual said. I really didnt need to but did anyway. It uses AA rechargeables so in a bind I can used regular AAs. I had a Remington before this one. I had to change the foils every 3-4 months. After a year I couldnt use it without it being plugged in.
  10. Corey 78K5
    Corey 78K5 1 ton status
    13,055
    Humboldt County, CA
    Electric razors = squat to pee
  11. chevyfumes
    Feb 24, 2000
    38,584
    266
    :haha: :haha: :haha:
