Electric Rear Window
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by FergsK5, Aug 20, 2003.
  1. FergsK5
    FergsK5 Registered Member
    May 5, 2002
    20
    Moncks Corner, SC
    Anybody have any knowledge of a switch that detects that the tailgate is closed? I've heard rumor that the window will only go up (using the switch) if the tailgate is in the closed position. Mine will not go up at all, only down. I belive, if this switch does exist, that it may have gone bad and could be the problem. Any ideas?
  2. TxK5Blazer
    TxK5Blazer 1/2 ton status
    Aug 13, 2000
    593
    Floresville, Tx
    I know there is a switch and I had that problem myself one time the switch was just not triggering at all I gave the tailgate one good closing and never had anymore problems with it at all .....Jason hope that helps
  3. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    Yes this switch does exist, look inside your tailgate, at either one of the latches, one side will have the switch, just unplug the wire from the switch, cut the plug off, and splice the wires back together. Switch will then be eliminated /forums/images/graemlins/thumb.gif
  4. vince13
    vince13 1/2 ton status
    Dec 6, 2001
    105
    Penticton, BC Canada
    yeah the switch is on the right side of the tailgate near the bottom. just caut and splice together and problem solved
  5. RustBuket
    RustBuket 1/2 ton status
    Feb 21, 2003
    1,618
    Saskatchewan, Canada
    I may have to do that....
  6. FergsK5
    May 5, 2002
    20
    Moncks Corner, SC
    Well, I found the switch and it was bad. I bypassed it and still no luck. I can;t figure it out. I have another tailgate in perfect condition, and i may just put that on. It is a manual, so i wouldnt have any problems there. I just don't want to have it painted to match, I'd rather be cheap. Anyways, thanks for your help. Any more ideas would be appreciated.
