Electric Taigate????
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by magnum4x4, Mar 10, 2004.
  1. magnum4x4
    magnum4x4 Registered Member
    Jan 4, 2004
    97
    Baltimore, MD
    I have a tailgate I want out of an 88' Blazer. The truck has no motor, battery....etc... What is the best and easiest way to roll down the electric window? /forums/images/graemlins/ears.gif
  2. lt61173
    lt61173 1/2 ton status
    Apr 9, 2002
    105
    Republic, Pa
    you can disconnect the part that goes to motor to the regulator and do it by hand. you may need a screw driver but i don't remember, i have done it.
  3. chev4life
    chev4life 1/2 ton status
    Jun 21, 2001
    416
    San Jose, CA
    You could always hook up a 9v bat to the input line on the tailgate motor. Will go slow, but work.
  4. dave_90_blazer
    dave_90_blazer 1/2 ton status
    Jan 1, 2004
    688
    Melvindale, Michigan
    cordless drill, use it to pull the screws on the cover, then use it to spin the drive cable
  5. mud390
    mud390 1/2 ton status
    Oct 31, 2002
    1,210
    Little Rock, Arkansas
    Disconnect the motor and clamp on a set of vice grips to the regulator and turn away. That is what I am doing currently. Ghetto? Yes! But it works for now.
    Kris
  6. daleearnhardt01
    daleearnhardt01 1/2 ton status
    Aug 29, 2002
    3,223
    Richmond, VA
    Easiest way /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif
  7. emoo99
    emoo99 1/2 ton status
    Jan 16, 2003
    494
    Washington
    Yep that's the easiest way if it does have the blue cord connected to the gears if not get in the truck, pull the cover of the tailgate, get a flashlight and on the left side about the middle of the tailgate will be some gears, put a screwdriver up in there and start turning, takes a while to find the right spot cuz it's behind a metal piece.. there's a dude on ebay sellin a new motor for $60 i'm buyin some tailgate straps from him and a new wire that attaches to the motor, pm me if you want his e-mail address..
  8. zach78k5
    zach78k5 1/2 ton status
    May 14, 2000
    406
    dave 90 has got it. use a cordless drill and just connect it where the cable connected to the motor. the window will probably roll up and down smoother than it ever did with the motor.
