electric windows
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Sammy, Feb 17, 2001.
  1. Sammy
    Sammy 1/2 ton status
    Dec 8, 2000
    Me right side window will not go up anymore. I'm missing a 12 volt point. It still will go down though. But why can't I get it up with the switch on the left door that opperetes the right window? Even, why does that switch do nothing at all when I pull the switch out from the right door?
    "K5 Grand GT in the Netherlands."
  2. bablazer73
    bablazer73 1/2 ton status
    Apr 4, 2000
    upstate ny
    your switch could be bad on the pass door. when the switch is in it's normal position, the power transfers through the switch. if the switch is bad, the power from the drivers switch can't go through. It's also common to have harness problems in the door hinge area's.
    your right. I don't understand the jeep thing!
