Electrical and gauges
Discussion in 'The Garage' started by oleo, Mar 26, 2007.
  1. oleo
    oleo Registered Member
    Feb 5, 2007
    64
    albuquerque
    Okay I searched, but I couldn’t find anything that would answer my question, partly because everyone else on here has a better understanding of what they are doing with their rig. So I am cutting everything off of this truck I can I am fabricating a new dash and roll cage. My question is electrical, I would like to be able to drive it on the street so headlights, turnsignals, wipers, horn, oil pressure, speed, tach, fuel, voltage, temp gagues are going to be new. My question is how much trouble would it be to do all of these new without using the wiring harness? Or do I have to use the harness (stock mess). Also what else would be good to have a gauge for?
    Thanks,
    Olaf
  2. ryoken
    Jun 13, 2003
    29,624
    1,380
    Jersey Shore
  3. 73k5blazer
    Dec 28, 2001
    4,987
    38
    The Rustbelt
    Not too much trouble, you just need a basic understanding of how vehicle electrical systems are put together.
    You need a fuse box of sorts, some quality wire (like SXL or GXL rated) and have at it. You can buy a new T/S switch, wiper switch, headlight ignition switch etc. If you going completely aftermarket, there are universal t/s, headlight, ignition switches out there.
    What may also be good for you is a basic painless kit which will replace all the underdash wiring and connectors and the fuse box with a new one.
  4. oleo
    Feb 5, 2007
    64
    albuquerque
    Carb
  5. ryoken
    Jun 13, 2003
    29,624
    1,380
    Jersey Shore
    super simple....
    you can do a small premade fuseblock...
    or you can go my route, figure out the circuits, and improvise... It's really pretty simple.. Ya ocassionally get something complicated, but it's usually just feeds, signal wires, grounds, proper circuit protection, etc... If you break it down into systems, is easy...
  6. oleo
    Feb 5, 2007
    64
    albuquerque
    So would I be off of my rocker to just remove all the junk associated with the dash and do it myself? New fuse box with a jumper to add more circuits and set it all up myself for lights, wipers, etc etc etc...?
  7. ryoken
    Jun 13, 2003
    29,624
    1,380
    Jersey Shore
    Nope, some time and a couple migraines later, you'll have a system... :wink1:
    maybe go with a small universal...
    http://store.summitracing.com/partd...&part=PRF-10101&N=700+400012+115&autoview=sku
