Electrical blues
Discussion in 'The Garage' started by Rusty68, Nov 28, 2004.
  1. Rusty68
    Rusty68 1/2 ton status
    Jan 22, 2003
    116
    Elko, Nevada
    I am having some issues I cannot figure out on my 78 gmc. When I turn on the head lights my gauges go weird. The volt gauge goes bottomed out to the negative, my temp gauge maxes out, as does my fuel gauge. If I move the dimmer switch the gauges move with it. I cleaned all the connections for the head lights as well as there ground wires and no change. I am lost on what to do. Could a bad light switch be causing all this? Any help would be great before I just take the truck to the dump. S.O.S!!!
  2. Rusty68
    Jan 22, 2003
    116
    Elko, Nevada
    Just a little up date, I tore my truck to bits trying everything. I sanded every connection replaced every switch altenator etc. Finaly it was working good. So i go to leave for a test drive. Pulled the ebrake lever and poof, my dash lights go out and my gauges go off the hook. WTF????? I push the ebrake on and they all return. Well it appears that there is a little ground wire for the whole dash power grounding threw the ebrake bracket. I knew this as I had cleaned it already. Turns out there was corrosion between the bracket and the body. Tightened down the bracket bolts and all is well again. I swear, somtimes I think this truck is gonna give me grey hair, but down the road it still goes. /forums/images/graemlins/thumb.gif
  3. 85mudblazin
    85mudblazin 1/2 ton status
    Mar 26, 2004
    3,951
    Austin,TX
    my vote is to re-wire, sounds like you have some pretty crossed up wires /forums/images/graemlins/doah.gif
