Electrical connector. What was it for?
Discussion in 'The Garage' started by cybrfire, Oct 24, 2004.
  1. cybrfire
    Dec 15, 2002
    15,139
    565
    Iowa
    Long enough to reach a chevy distributor or cruise control maybe or anything else middle back of block?
  2. 4X4HIGH
    Dec 14, 2001
    22,060
    69
    Pleasanton, CA.
    It appears to be an oil pressure sender wire. Depending on the year of vehicle you are working on you may find 2 sender wires, (1) was for the actual oil pressure gauge and the other was for a pressure swith to keep the electric fuel pump running should the fuel pump relay go bad.
  3. CyberSniper
    Apr 21, 2003
    2,257
    5
    Chelsea, MI
    Looks like the oil pressure switch for the electric choke. They're usually located down by the oil filter boss.
  4. cybrfire
    Dec 15, 2002
    15,139
    565
    Iowa
    I should have said it earlier but this is an 85. Also the second picture there is a connector in the background that I'm fairly certain is oil pressure. It's been apart for a long time and some of my labels have gone missing.
  5. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    look on your wiring diagram for a plug that has those 3 coloured wires
    then post back and tell us what it is
  6. CyberSniper
    Apr 21, 2003
    2,257
    5
    Chelsea, MI
    Well, on the back of the intake between the distributor and the cruise control servo there is usually a sensor. If it is an idiot oil light it has a little "can" and if it is an oil pressure gauge it has a "large" can. It only has one male spade terminal on it.
    You can see the pressure gauge sender in this crappy picture. It's on a brass 45° to clear the cruise control servo.
  7. cybrfire
    Dec 15, 2002
    15,139
    565
    Iowa
    I can't find my diagrams. Got burnt to CD and that as good as lost. I'll find them eventually. Apparently its not needed in my case. Some of the wires were cut off long ago and taped off. I basically just shortened them this time and tucked em back in till I positively identify what they were for.
    My old oil pressure on the small block was the big can for the gauge.
  8. rubbinz raczn
    rubbinz raczn 1/2 ton status
    Oct 4, 2004
    656
    too far north!
    i have a diagram. what color are the wires?
  9. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    It is certainly the oil pressure switch for the electric choke, as stated above.
  10. hardcore71
    hardcore71 Registered Member
    Nov 21, 2002
    86
    Weare NH
    Yup, Electric choke oil press sensor connector. On 85's it's up by the distributor nect to the sender for the gauge or light. The 2 sensors are on a T threaded into the port at the top of the block.
  11. cybrfire
    Dec 15, 2002
    15,139
    565
    Iowa
    So, If I understand correctly, I don't need it. I will be using a manual choke anyhow.
  12. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    could it be the plug in for the AC? looks like your truck used to have AC but you took it out. ill have to take a pic of one.
    it also looks like the sensor that is above the oil filter on the side of the block, but it looks to big. /forums/images/graemlins/thinking.gif
  13. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    i had the exact same connector on my 82, wasnt hooked up when i got it, just hanging under the truck. when i rebuilt the engine, since it ran fine with it hanging, i just tied it up. never had any problems with it, nor did i find out what it was.
