Electrical distribution block question
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by utchev, Jun 21, 2005.
  1. utchev
    utchev Registered Member
    Aug 17, 2004
    91
    Salt Lake City.....
    Background: '89 Suburban K1500 wiring harness, TBI 350/700, D60/14 bolt etc. getting swapped into a YJ (you know, a Jeep item that'll think it's a K30)....... This swap seems incredibly easy until I've gotten to this particular point. If I remember correctly, there is some kind of fusible link that goes from the electrical distribution block to the starter. The distribution block I have from the K1500 does NOT have a a 'bridge' from post to post as I've seen others have (on my tow rig, an '89 K2500 Sub--kinda nice to have a full working model for the swap).
    Oh, and thanks for any help!
    Question(s):
    1) What gauge of wire is the fusible link from the distribution block to the starter?
    2) Do I need the 'bridge' piece and if so, where can I get it (I've thought of running an inline fuse, but don't know where to even start with a 'safe' amperage) and what is it actually called?
  2. dyeager535
    26,982
    191
    Check the garage the post I just made about codes/wiring info. There's a link to Autozone's online wiring manuals, hopefully that can help you out.
    As I understand the *older* truck wiring, the wires from the starter run up to the distribution block, and are fusible linked from there to the fuse panel. I checked the '86 wiring manual I have, I couldn't find where it showed how that block is wired.
  3. dontoe
    May 7, 2004
    9,070
    Hickory, N.C.
    I replaced the fusible links on both my Blazers with 60 amp circuit breakers. That way if I do ever have a short, they reset automaticly. No problems even with A/C running.
  4. utchev
    Aug 17, 2004
    91
    Salt Lake City.....
    Checking....... got a link or other reference? (this one? http://coloradok5.com/forums/showthread.php?t=141717 )
  5. dyeager535
    26,982
    191
    Here ya go
    I was going to name the link "wiring guides", but as I backed up from the original link I found posted, I realized the site has more than just wiring diagrams.
