Electrical fire. burb's offline. *Updated*
Discussion in '1936-Present Suburban' started by Ddragggon, Mar 24, 2003.
  1. Ddragggon
    Ddragggon 1/2 ton status
    Apr 25, 2001
    2,657
    Hartford, WI (formerly Etiwanda, SoCal)
    Electrical fire. burb\'s offline. *Updated*
    /forums/images/graemlins/angryfire.gifprevious owner was a complete donkyraping s***eatnig F***ing moron.. I wish I'd ripped the wireing harness appart sooner, since it was obviously a complete re-wire job. the previous bastard used ( as I learned when I was prying appart the melted engine harness) AC home electrical wire, instead of the proper DC wire. I was able to limp it home by taking the alternator power lines, and voltage regulator lines, and directly attatching them to the battery, along with the main harness powerline ( should be from the starter) and foregoing the now melted lines where the fuseable links SHOULD HAVE BEEN /forums/images/graemlins/angryfire.gif (insert about 5 minutes of cussing that'd make a dirty sailor blush)
    the good news is, I've got 2 replacement harnesses for the damn thing... the bad news is, they're both 60 to 80 miles away...
    -Rich
  2. azblazor
    May 5, 2001
    1,953
    Arizona, Phoenix area
    Re: Electrical fire. burb\'s offline.
    At least now you HAVE to fix it /forums/images/graemlins/smile.gif
  3. Ddragggon
    Apr 25, 2001
    2,657
    [/ QUOTE ]no I don't, I can just drive it hotwired until it burns the whole truck down. /forums/images/graemlins/grin.gif
    -Rich
  4. Ddragggon
    Apr 25, 2001
    2,657
    well, drove out to the parts truck today, and spent a good 3 hours pulling the entire engine, cluster, and lighting electrical harnesses out of the other truck. ( all that leaves is the dual AC harness) I also snagged the tilt column, since as I recall, its in much better condition then the one in the K20 right now. ( not only that, it has a full sized chevy wheel on it, instead of that tiny crap one someone installed so long ago)
    now all I gotta do, is inspect the whole thing, replace worn wires, and then find some time to install the damn thing ( prolly tomorrow afternoon) and see if it works.
    -Rich
