electrical fire.. help!!!
Discussion in 'The Lounge' started by wraenking, Jan 14, 2005.
  1. wraenking
    wraenking 1/2 ton status
    Apr 30, 2003
    1,493
    Toms River, NJ
    holy smokes, thank god i was home. i have a turtle enclosure in my garage that i run the pump, a couple of heaters, heat lamp, and a flor light. my buddy happened to be looking at the zip strip, and it caught fire???
    its been set up like that for a year and a half. any suggestions why it just happened? or could it just be the zip strip went bad???
    thanks
  2. ryoken
    Jun 13, 2003
    29,623
    1,379
    Jersey Shore
    don't be frying them there turtles! :shocked:
    hope you didn't have that fancy new welder hooked up to it... :wink1: sounds like it may have just had too much juice running thru it... buy a quality one when ya replace it...
    couldn't take work off huh? :tongue1:
  3. kennyw
    kennyw N9PHW Premium Member
    Jun 9, 2002
    13,223
    94
    Stevens Pass Highway, WA
    What was the total Amp load on it? You need to be sure the power strip, outlet and house wiring is rated higher than the load.
  4. ronnny
    ronnny 1/2 ton status
    Nov 22, 2004
    838
    Newnan GA
    Loose wire or wires. To many amps. Loose wires cause the amps to go up and cause heat that turns into a fire. Make sure you check around and feel the cords that go to different things and the outlets that have alot pluged up to them if they are warm then they may be next. Check this everynow and then especially with all the heater use now. People don't do maintenance around the house like they should and check things. Listen to the firemen give the kids safety lessons.
